dont think i ever posted this
Old Feb 10, 2004 | 08:10 PM
agentAndy's Avatar
more class than college
Default dont think i ever posted this
300@wheels STOCK with intake and exhaust only. stock boost. notice the fuel cut. i think i have a bad map. the car runs RICH ALL the time. real rich. the car will throw the code for turbo pressure sensor when this happens. it happens at full boost and full load only. like i said i think it is a bad map sensor. any ideas from you? the dyno tech said i would have hit 320@wheels if this didnt happen. i still had another 1200 rpm to go. i must have gotten a good clip from jarco
Andrew Carroll @ XAT RACING
team v8 in the works. hold one tango.....
hot hot heat in the cup!!!
Old Feb 10, 2004 | 08:35 PM
Slash's Avatar
THE HAMMER
sounds liek it... very impressive
I dont feel like a sig today.
Old Feb 12, 2004 | 01:46 AM
marksaccord95's Avatar
TR Registered Member #5
mmmm.... the air fuel is 13/1..... thats far from rich.....
http://www.floridaracing.org
Old Feb 12, 2004 | 07:48 AM
93supra's Avatar
Yeah need to be careful with your A/F I'm hoping this was with race gas.
Old Feb 12, 2004 | 12:48 PM
agentAndy's Avatar
stoich on pump gas is around 12/1
Old Feb 14, 2004 | 06:54 PM
flubyux2's Avatar
Elitist Supra Asshole :)
no... stoich is one pound of fuel for every 14.7 pounds of air...
less than 14.7 pounds and its "rich"... more than 14.7 pounds and youre "lean"
13:1 on a stock motor in stock trim and stock tune is fine. when the boost gets cranked and running hotter IAT's, then running richer will be necessary.
Old Feb 15, 2004 | 11:18 AM
agentAndy's Avatar
you learn something new everyday. thank you
Old Feb 15, 2004 | 12:37 PM
hachibill's Avatar
yea sweet lemonade
get a S-AFC and you should be able to take care of the fuel cut and the lean run condition. and make shure your fuel pressure is where its supposed to be.
Old Feb 15, 2004 | 10:45 PM
agentAndy's Avatar
stock fpr. could that be wack?
Old Feb 16, 2004 | 04:07 PM
flubyux2's Avatar
stock fpr could possibly be a culprit of running unusually lean... but it wont cause fuel cut.
