5sfe
Old Aug 13, 2003 | 09:20 PM
Plopokiller's Avatar
HoHo's
Default 5sfe
Im planning on bosting my camry. So far i have Supra tt fuel pump, injectors, vortec FMU, MSD ignition. Im just intrested in turbo info. I was planning on getting 3sgte but i just trust my 5sfe!>! Thanx guys
2640lb.
227.5 RWHP
Old Aug 13, 2003 | 09:38 PM
TurboJZA70's Avatar
Old School "Turbo" dude
if money is not an issue do the 3s swap, if money is get a turbo and manfold from a mr2. (3S-gte) and it will bolt right up to your 5s,
you will need to make a downpipe, oil and water lines to make it all work, and a few fuel system tricks to get it to handle boost.
nothing about the turbo conversion is very hard. can be completed ina day or so.
Buy a TR email address Here
Old Aug 14, 2003 | 07:17 AM
HoHo's
i have the manifold the turbo and down pipe i just dont understande the fuel system to handle boost.
2640lb.
227.5 RWHP
Old Aug 14, 2003 | 08:30 AM
MR2driver's Avatar
not available
For it to be safe, I recommend a rising rate boost dependant fuel pressure regulator, 440cc injectors, and an MSD BTM (boost timing master) to control ignition timing. If you get all these things mentioned above, and your engine has lower miles, you could run 10-12psi safely for awhile till the headgasket lets go.
Old Aug 18, 2003 | 01:29 PM
T88MR2's Avatar
P.I.M.P.
I recommend that you do the 3sgte swap there good motors and they produce a good amount of horsepower also if you do decide to do that replace your crank with the 5sfe it will increase your displacement making it a 2.2L you will have a serious Camry
Old Aug 18, 2003 | 02:21 PM
dan's Avatar
dan
Get the fuck off my lawn
if u have the injectors you dont really need the vortech fmu, those are usually used for stock injector setups. go with what mark said and pick up a $150 aeromotive rrfpr and a minigauge and that will defnately help, esp when getting it tuned. maybe even pick up an s-afc.
as far as the 3s swap depending what year your camry is you might have alot of work cut out for you. and the stroker kit isnt as simple as bolting in a 5s crank in a 3s block. the rods have to be custom length and etc etc. 5s-fe block with 3s-gte head wouldnt be cheap either, i dont remember teh specifics of this.
