Help 2004 wrx won't start
Ok so my slave cylinder gave out the other day , not a big job got a new one put it in and now the car won't start, took the battery out and the starter out both tested good, checked voltage the starter and it is getting 12 v. Tried changing my relays around under the dash nothing, some one please help me 727-687-1555, will pay for some one to fix !!!
does the car crank ? can you hear the fuel pump before you attempt to turn it over ?
spark, timing, and fuel are your friends.. chances are your down to looking for spark and fuel. |
Car does not turn over at all no clicking, I can hear the fuel pump turn on
did you remove any ground wires ? Is there a safety switch on the clutch you forgot to reconnect ?
i just got done doing a rebuild on my second motor, so idk if any grounds are wrong, getting a different starter tomo hopefully its the solenoid on the starter well see.
Car runs it was the ground wire from the trans to the fire wall
Originally Posted by kallday
(Post 9219427)
Did you have to replace it or was it just not connected? Mine literally burned up. Crazy... running amplifier ground wire now lol.
I did not have to replace it I must have knocked it off there when is was doing the slave cylinder, yea I don't get why there so small , I would have never though that wire was a ground wire
