Subaru Tech All We'll Drive
Problem installing TMIC (need silicone hose supplier locally)
Old Jul 10, 2008 | 07:35 PM
mantra1's Avatar
Shaggin' Wagon IV
Default Problem installing TMIC (need silicone hose supplier locally)
So I went to install my MRT TMIC and the silicone hose is about 2" too short from the exhaust outlet.
Who sells silicone hose locally? I need about a 5" straight section (2" ID) and run a coupler joining the 90 deg bend.
Any help is appreciated.
Old Jul 10, 2008 | 08:24 PM
Alizarin's Avatar
Gravel fiend
I'm assuming you mean the turbo compressor outlet, not exhaust outlet?
Have you considered just getting some 2" ID aluminum pipe (thin wall), cutting the silicone hose, and just clamping it in to extend it?
Old Jul 10, 2008 | 08:47 PM
Apexi wrx's Avatar
The NExt Brian O' Conner
amazon hoses off 60 and 41
Vroommm psshhh
Old Jul 10, 2008 | 08:48 PM
racer_x's Avatar
vroom psshh.
+1 this is the best way to go.
Old Jul 11, 2008 | 03:39 AM
-faded-'s Avatar
infraction king
amazon will have what you need in stock or you can do the pipe trick. either one will do.
98 E36 ///M3 Sedan
07 Civic Si Sedan
Old Jul 11, 2008 | 04:18 AM
mantra1's Avatar
Shaggin' Wagon IV
I plan on doing the pipe trick anyways, just futher away from the compressor outlet. Thanks to Paul and James on the local hookup.
