Subaru Tech All We'll Drive
BMP Results - 6/19/08 - Bradenton Speedway
Old Jun 19, 2008 | 07:55 PM
racer_x's Avatar
vroom psshh.
Default BMP Results - 6/19/08 - Bradenton Speedway
I knew my car would be slow, but I wanted to run it anyway to set the benchmark for when I get everything fixed.
My 2 most impressive runs:
13.1 @ 104.5mph ; 1.8 60'
13.6 @ 89.0mph ; 1.76 60'
My car problems:
2 boost leaks, one major
Tune is WAAY off for my current setup
Tire pressure was very low
Clutch is not pressurizing properly (needs to be bled, filled). Because of this... I couldn't grab 5th gear!!
I can't wait to get my car done and go back... with all the little supporting mods I'm about to do (I consider it stage 2 +) the car SHOULD be in the low 12s... Fun night, guys, thanks to all those who showed up!!
Old Jun 19, 2008 | 08:41 PM
1320 Engineering's Avatar
not bad.. my best was 12.60@107.7 with a 1.75 sec 60ft
edit: horrible.... just found a boost leak... must have been there last night too
1320 Inc./////
Call - 813-842-0505
Email Info@just1320.com
http://www.just1320.com
8602 Temple Terrace Hwy. C-14
Tampa FL 33637
4ws tuning
Boost Lab
Old Jun 19, 2008 | 08:47 PM
flystiguy01's Avatar
Skunk.
12.3@113 1.72 60'
The thing I hate about an argument is that it always interrupts a discussion. -G. K. Chesterton
Old Jun 19, 2008 | 08:49 PM
blacksti's Avatar
DudeMan
My car problems:
holy hell i did 88.9mph in the 1/8 with stock turbo... how fucking bad is that leak? and wheres it at?
well low tire pressure is better for the strip but damn you need to fix your car!
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old Jun 19, 2008 | 08:51 PM
blacksti's Avatar
DudeMan
and howd you manage a 13.6 with 89mph trap? that just doesnt seem possible
2jz mustang build
Old Jun 20, 2008 | 02:10 AM
ugmSTI433's Avatar
Classy STI Driver
13.645 @ 98.25 with a 1.88 60' Trap is horrendous Oh well, it was fun that's what matters
Andrew's 2007 UGM STi Limited #433
Defi Red Racer Boost + Oil Pressure | Innovate WB A/F | V1 radar | Cobb AP protune | Spearco TMIC | APS 3" catted TBE | APS CAI | APS turbo inlet | DeatschWerks 750cc injectors| Walbro FP | Beatrush forged pitching stopper | Kartboy hangers |Coolant bypass | Prodrive EBCS | Debadged trunk | Cobb heatshield |DRL delete | Autospeed dead pedal + black license plate trim | Primitive Armor |
284whp/307wtq
(mustang dyno)
Old Jun 20, 2008 | 07:56 AM
racer_x's Avatar
vroom psshh.
I know, but I've got the slip to prove it. it was otherwise a good run, but I couldn't grab 5th! So I basically had to tack out 4th. My car's normally pretty dern quick, quicker than it should be...
Old Jun 21, 2008 | 06:06 PM
I'm Slow's Avatar
I'm Slow
sorry I didn't make it out. I did take the car out Saturday with the lighter rims but I had issues all day and the 90 deg + did not help. My best and unfortunately only clean run was 12.4@ 108 with a 1.7 60 ft. The rims definitely helped, the car has 12.2 in it but I need more practice. I have been going to BMP a lot lately, we should keep doing this......it's always more fun with subies around. Anyone going back soon?
Old Jun 22, 2008 | 05:01 PM
badmutha's Avatar
mad scientist
got my new clutch in and im ready to see what mine will do, never went down the 1320 bet it is fun,plus i get to see where all that hard earned money went!
Old Jun 23, 2008 | 08:17 AM
I'm Slow's Avatar
I'm Slow
^if you can drive it good then your car should easily be low 11's.....with the right tires and excellent driver.........dare I say 10's
