Subaru Tech All We'll Drive
final clutch question -- we're almost there...
Old May 24, 2008 | 10:55 AM
racer_x's Avatar
vroom psshh.
Default final clutch question -- we're almost there...
chris and I can't figure this one out. My car will shift gear, but only when off -- the clutch actuator works the fork, which is moving the throwout bearing. If we start the car in gear, we can drive in that gear no problem. When we try to shift, however, its locked... if you persist, you grind gears.
What on earth is going on here?
Old May 24, 2008 | 11:51 AM
flystiguy01's Avatar
Skunk.
for anyone thats trying to help, the clutch is getting pulled away from the flywheel but it seems like its not getting pulled enough... the clutch slave cylinder is moving the fork the same amount of another STi that were using for reference.
could the throwout bearing be faulty and not grabbing the clutch enough? or since we're going from an OEM clutch to a Southbend modified exedy unit (solidmass) do we need to adjust anything?? homemade, your needed... lol.
The thing I hate about an argument is that it always interrupts a discussion. -G. K. Chesterton
Old May 24, 2008 | 06:46 PM
racer_x's Avatar
vroom psshh.
UPDATE: car fixed itself.... I/we can't take credit for this one.
Old May 25, 2008 | 12:02 AM
anarchypro's Avatar
fozzy tech
well thats good im glad to see ur slow car is working again
Tampa bay tuned inc.
Old May 25, 2008 | 12:14 AM
blacksti's Avatar
DudeMan
was the fork not seated in all the way?
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old May 25, 2008 | 06:01 AM
Skunk.
no the fork was seated fine. basically we just played with the clutch pedal for like 30 mins and then bam all of a sudden we could shift.
Old May 25, 2008 | 07:35 AM
racer_x's Avatar
vroom psshh.
hahaha I love it... and I'm so glad we didn't screw with it anymore. yes Nick, I'm finally slow again! really slow, in fact...
In fact, I challenge Joe to a race to find out who really is the slowest!
