Subaru Tech All We'll Drive
Brake Lights issue????
Old Nov 4, 2007 | 07:35 AM
SOTO's Avatar
Default Brake Lights issue????
Ok so this past week the hand brake in the gauge cluster light just comes on randomly or in between shifts. I have checked the switch at the hand brake and I have found nothing wrong with it. I am not sure where else anything could go wrong. Anyone have any ideas?
Old Nov 4, 2007 | 08:38 AM
-faded-'s Avatar
infraction king
check your brake fluid level
98 E36 ///M3 Sedan
07 Civic Si Sedan
Old Nov 4, 2007 | 08:40 AM
xxBoost Junkiexx's Avatar
MPG FTW!
Old Nov 4, 2007 | 10:34 AM
SOTO's Avatar
just checked it, it is a little low that brake lights sences the hand brake and the fluid level?
Old Nov 4, 2007 | 10:40 AM
-faded-'s Avatar
infraction king
no, but with it being low and the motor sometime jerked around between shifts could cause it to tip to one side triggering the sensor that it is low. your ecu will tell you your fluid is low by your e-brake light coming on. sounds like your is barely above where it needs to be just moves around sometimes during shifts causing it to read low.
98 E36 ///M3 Sedan
07 Civic Si Sedan
Old Nov 4, 2007 | 10:48 AM
SOTO's Avatar
ahhh i see this is a smart car well my next question is it should be a closed system so how do you get low on fluid unless there is a leak which in that case how would i find it? unless i am all wrong about it being closed
Old Nov 4, 2007 | 11:03 AM
-faded-'s Avatar
infraction king
got to think, your car is 5 years old. over time it is going to use up some fluid. i know you beat on it sometime so there is heavy braking at time causing the fluid to be more rapidly used.
98 E36 ///M3 Sedan
07 Civic Si Sedan
Old Nov 4, 2007 | 11:56 AM
SOTO's Avatar
well thank you sir, i will be putting in some fluid and seeing what happens.
Old Nov 4, 2007 | 01:45 PM
djerickd's Avatar
CHILLING SPREE!!!
you should probably just flush the system while you are at it... who knows how old that fluid is now.
SnowMan Tuned
Old Nov 4, 2007 | 03:47 PM
SOTO's Avatar
there was not that much missing but i guess enough to trip it. I added just a little bit and it worked. thanks faded
I do plan on flushing it just need the time to do it.
