Subaru Tech All We'll Drive
Muffler question
Old Feb 19, 2007 | 03:48 AM
blacksleeper's Avatar
Giggity Giggity Gone
Question Muffler question
Is it possible to weld a muffler that has a 2.5 in. inlet to a 3 in. pipe? Do they make some type of coupler you can use to do this. I figured it should not affect the flow to much and was curious if you could get it to fit.
Old Feb 19, 2007 | 07:45 AM
JonLGT's Avatar
Just for decoration
Im sure any muffler shop could do it.
Old Feb 19, 2007 | 09:13 AM
KAX's Avatar
KAX
muffler shops should have a reducer they can weld onto the 3" pipe to make it into a 2.5" My question is why would you want that?
Old Feb 19, 2007 | 11:13 AM
Alizarin's Avatar
Gravel fiend
I'm no Mechanical Engineer, but I do work with a few who are car junkies.
As the exhaust gases cool down, volume contracts (See PV = nRT from chemistry) and gas velocity gets slower. Thus, having 2.5" ID instead of 3" exhaust near the axle-back is not as big of a flow reducer as, say, having 3" to 2.5" close to the turbo. If anything, we're talking 1 or 2 horsepowers here. I don't think it'll be enough to notice at all.
Turbo XS even used to sell a midpipe that would bolt to their monster DP and taper for use with stock or 2.5" axle-backs.
Old Feb 19, 2007 | 04:06 PM
there are a lot more 2.5 in mufflers available then there are 3 in. the style i like is in a 2.5 so i wanted to see if it would fit. trying to quite my custom exhaust a little bit.
Old Feb 19, 2007 | 07:25 PM
smooth_ej20's Avatar
josh, why not see if they make a silencer for your muffler. I had one on my Apexi on my neon and it quieted it down a lot and they usually dont restrict that much. Plus you have the option of taking it out should you hit the track or dyno.
Old Feb 20, 2007 | 09:13 AM
mike, i have a silencer but it only screws in on one side so it vibrates. the other thing is i hate the way a silencer looks in my exhaust. i also just bought a high flow cat that will be going in this weekend so we will see how much of a diff. it will make. i still might buy a muffler if i can find one that looks like the stock dual tip. my neighbor is a retired welder so he will do all my exhaust work for free.
Old Feb 20, 2007 | 06:41 PM
QuickSC2 3HT's Avatar
Sick of the noise or did you get an exhaust ticket? Mine is really quite its got a resonator or maybe muffler after the flange where the cat would be. I ll take a pic if you like, then the rear doesn't change at all.
'02 Subaru WRX 2.5L, SR40 turbo, MRT TMIC, RA gears, ACT clutch & flywheel
'06 Chevy Cobalt SS GM Stg 2 G85 lsd
'94 Acura Integra GSR sold
'99 Isuzu Rodeo 4x4 2" lift, Procomp 9000 shocks, 20" Procomp Knight Khrome wheels sold
'92 Acura Integra RS sold
'04 CRF450R '86 TRX250R
Old Feb 20, 2007 | 06:42 PM
Its got an MRT uppipe to the SR40, 3" downpipe no cat then MRT cat back for those of you not familiar with my car.
Old Feb 21, 2007 | 12:21 PM
Alizarin's Avatar
Gravel fiend
You could always buy a resonator and have it inserted into the midpipe if you want to cut down on the noise. The high-flow will cut down some also.
