Subaru Tech All We'll Drive
walbro fuelpump
Old Dec 9, 2006 | 09:53 AM
blacksti's Avatar
DudeMan
Default walbro fuelpump
how hard is the install on the one of these?
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old Dec 9, 2006 | 10:29 AM
blacksleeper's Avatar
Giggity Giggity Gone
15-20 min. not bad at all. all you have to do is remove the rear seats and pop open the top of the fuel tank located right behind the seat. pull the whole unit out very carefully so not to damage the float rod, and then just remove the old pump....clip in the new pump and put the unit back into the tank. bolt everything down and your done.
Old Dec 9, 2006 | 10:30 AM
also i've heard it's better to use the stock fuel filter bag instead of the walbro one.
Old Dec 9, 2006 | 12:36 PM
blacksti's Avatar
DudeMan
the guys at racing zone said the 06 stis are harder and you have to tap something but ive never heard about that.. i thought it was just a drop in pump
2jz mustang build
Old Dec 9, 2006 | 01:30 PM
it should be a drop in, unless the clip for your pump is different than the walbro. otherwise i have the extra wiring harness that came with the walbro if you need it.
Old Dec 9, 2006 | 01:33 PM
fat angel's Avatar
Secret Squirrel
the pump is no different. they only change was the addition of a slosh box around the filter. no tapping anything just drop it in.
Old Dec 9, 2006 | 05:37 PM
KAX's Avatar
KAX
only PITA part is getting the little rubber grommet thing on the bottom of the pump into its place. other then that its really easy.
Old Dec 9, 2006 | 06:59 PM
djerickd's Avatar
CHILLING SPREE!!!
you don't have to remove your rear seats if you have some of those right angle phillips screwdrivers, make sure to relieve the pressure in the lines if you don't want to pass out from the gas fumes
SnowMan Tuned
Old Dec 15, 2006 | 08:02 AM
vtec2STi's Avatar
Steve
I did it on my 06' STi and it was not difficult. It took about an hour.
I re-used the old bag and needed no other parts than the pump itself. Do not waste your money on the "adapter" kit like I did. It wasn't needed.
Old Dec 15, 2006 | 09:49 AM
SRQSTI's Avatar
Rippin n tearin!
it can be done that way but it so much easyer with out the back seat.
Car History
97 Civic Hx coupe--Sold
02 Wrx w/usdm Sti swap--Traded in
04 Sti --Sold
96 Civic hatch w/ ITR swap--Sold
90 Civic Wagon B16--Traded
90 4Runner v6 4x4--Sold
08 Civic Lx--Traded in
11 Sti SWP Sedan--Traded in
*11 4Runner Trail Edition 4x4 --DD
*08 FX35 -- DD
