Subaru Tech All We'll Drive
hub size
Old May 18, 2006 | 08:14 AM
3drwhore's Avatar
Pending....
Default hub size
I tried searching for it on google but had no luck. I was just wondering if anyone knew the size of the hub on the rotor. for a wrx.
Old May 18, 2006 | 08:27 AM
BrewPuBeaver's Avatar
*Big Schpellar*
like the circumfrance? or bolt pattern?
Old May 18, 2006 | 08:33 AM
3drwhore's Avatar
Pending....
Old May 18, 2006 | 09:09 AM
*Big Schpellar*
so you mean bolt pattern, or the circumfrance?
bolt pattern is 5x100
Old May 18, 2006 | 09:53 AM
schoellnasty's Avatar
I think he means the circumference/diameter of that circle inside the wheel studs.
Old May 18, 2006 | 11:21 AM
2TurboImports's Avatar
sooo...where's the turbo?
I think the rear brakes are the same on the wrx as the RS, I know the fronts are different...not 100% sure about the rears, though. Anyhow, if the factory service manual doesn't have the measurement you need you'd probably need to measure it yourself I guess? what's the measurement you need for?
Old May 18, 2006 | 11:27 AM
Alizarin's Avatar
Gravel fiend
The hub bore is 56mm. I think that's the measurement you're looking for.
Old May 18, 2006 | 03:46 PM
JonLGT's Avatar
Just for decoration
its 60mm on a vw also.
