Subaru Tech All We'll Drive
heat wrap ?'s
Old Mar 2, 2006 | 05:24 PM
smooth_ej20's Avatar
Default heat wrap ?'s
well on monday im pulling my exh. manifold to have it tapped and while its off i was thinking of heat wrapping it. ive heard good and bad things about heat wrap so i figured id ask some of you guys. I remember hearing esemes talking about it but i didnt catch the whole conversation. If it is a good idea where can i get some locally and which kind should i go with? id order some but if i decide to do it i want to to do it monday. thanks
Old Mar 2, 2006 | 07:00 PM
Apexi wrx's Avatar
The NExt Brian O' Conner
I was going to heat wrap my manifold today but its almost impossible to do it u will have spots that make it hard to wrao but if u can good luck
Vroommm psshhh
Old Mar 2, 2006 | 07:12 PM
marksaccord95's Avatar
TR Registered Member #5
if anything is ceramic coated, dont rap it. stainless is what ure suppose to rap
http://www.floridaracing.org
Old Mar 2, 2006 | 08:28 PM
well to clear things up i have the Fujitsubo Super Ex. Stainless steel manifold. there arent any tough spots. i was just wondering if there will be any really good benefits from it. and if i should wrap the whole thing.
Old Mar 3, 2006 | 08:59 AM
hihobibo's Avatar
Rock Star
I wrapped my U/D pipes as much as I could. If I could have got ceramic coated pieces, it would have benn better, but I had to go with the wrap.
The only bad things I've heard about wrapping is 1) it accelerates rust, because water gets trapped in there/the wrap stays wet longer than the pipes would normally, and 2) it can act as a wick if you get a flammable liquid soaked into it and it somehow catches fire.
Plus, it is really itchy if it touches your sking when wrapping it.
Old Mar 3, 2006 | 07:54 PM
nofearnick's Avatar
The best way is to ceramic coated it. On my up/down pipe I wraped it and the heat under the hood is alot lower now. No problems yet on mine but only been on for around 6 months.
