Subaru Tech All We'll Drive
Uh ohhhhh......
Old Dec 23, 2005 | 05:30 AM
HKSWRX's Avatar
Rraawwrr!!
Default Uh ohhhhh......
Yeah, I was nailing it out of a light last night, and about mid second gear it felt like my car hit hardcore fuel cut... so I give it some gas, and all I hear is enormous ammounts of boost leakage, so I assumed its an intercooler hose. But this morning after driving it for about 10 minutes to work, I opened the hood, and smelled coolant really strong, and I looked down in front of the motor, and sure enough theres coolant standing there, and I can hear it dripping from somewhere and sizzling on the pipes.
What the hell? DId I blow a gasket or something last night? Could that be boost leaking out of my head gasket or seals? Or are the problems unrelated?
www.myspace.com/beyondthemire
Old Dec 23, 2005 | 06:57 AM
SnowMann's Avatar
TR Shop Mod
Originally Posted by fadedSTi
kind of hard to answer if we dont know where the coolant is leaking from. see if your line came off the turbo. just start following all lines. run the car if you can to see if it spits more fluid
yep...try to clean things up a bit before you start to make the leak a bit easier to spot.
SnowMan tuning
Old Jan 7, 2006 | 08:13 PM
silverhkswrx's Avatar
what was/is the problem?
Old Jan 7, 2006 | 10:26 PM
Alizarin's Avatar
Gravel fiend
IIRC his IC hose from turbo->IC came off.
Old Jan 9, 2006 | 06:40 AM
HKSWRX's Avatar
Rraawwrr!!
Kennys got it right, it was actually no big deal
Also I just had to replace my right axle boot, was leaking gear oil out of it
