Subaru Tech All We'll Drive
gauge questions ????
Old Aug 7, 2005 | 07:07 AM
WRx'sTeR's Avatar
Default gauge questions ????
i was wondering about gauges ???? now is it better to get electrical or mechanical guages ???? and what 3 gauges should i get ??? i no the boost gauge what else for a turboed WRX
Old Aug 7, 2005 | 07:59 AM
I'm Slow's Avatar
I'm Slow
EGT and A/F wideband.-------> the best and most useful gauges.
Old Aug 8, 2005 | 03:38 AM
BrewPuBeaver's Avatar
*Big Schpellar*
^^^^not true^^^^ you dont need a Air to fuel ratio gauge if you have a EGT gauge. it is nice to have but not necessary. personally i tell people not to get a boost gauge.
if you are planning on gfetting 3 gauges look at spending at least 600 bucks. 3 gauges pod and install. if you are spending this much and you dont have a EBC. dont buy gauges. but if you are planning on spreading your mods out and just need something to read boost. get a mech boost gauge. if you are planning on doing the best set up that will be the most acurate. Eletric full sweep gauges are the way to go. you will be looking at around 200 bucks each for good ones. i know Gruppe-s has a 3 gauge+pod deal for like 750. i went with the HUGE 67mm Autometers in my car. EGT, Oil Temp, Fuel pressure. i will be adding 2 more some day probly water temp and a voltmeter.
Cliff notes.
no EBC dont buy gauges
Eletric over mech
dont get a A/R gauge
Old Aug 8, 2005 | 11:12 AM
I'm Slow's Avatar
I'm Slow
I didn't say you needed them. Just that they would be the best and most useful, which is 100% true. I would rather have a WIDE BAND A/f gauge rather which is more usefule then a fuel pressure gauge.
Old Aug 8, 2005 | 11:14 AM
*Big Schpellar*
if you have a EGT you can tell if your running rich or lean... if you have up graded fuel plans it is highly recomended to have a fuel pressure gauge....
Dave's .02
Old Aug 8, 2005 | 11:33 AM
I'm Slow's Avatar
I'm Slow
I was just stating that those are the best gauges to have, not to get both. misunderstanding......anyway my gauges that I have are wideband a/f, boost, and oil temp.
Old Aug 8, 2005 | 11:44 AM
*Big Schpellar*
agree'd
personally i would go for the EGT cause it is a more useful tuning tool.
