Subaru Tech All We'll Drive
horn&cruise control out of order
Old Sep 5, 2003 | 09:27 PM
722ish's Avatar
ASM FTW!
Default horn&cruise control out of order
wtf can i do? i checked fuses etc.. nothing seems wrong... its just the horn and steering wheel mounted control for cruise... the button on the dash lights up fine...
95 Supra Turbo 6 speed
11 SWP STI sedan
Old Sep 8, 2003 | 12:16 PM
Opie's Avatar
So now I'm a liar...
Question
Is your steering wheel stock?
There's a little contact ring thingy in there that could've gotten goobered up I suppose. Or possibly the harness got caught on something and pulled loose when the wheel turned....
Not usually if you have a stock wheel though....
TR...where details aren't important if leaving them out makes the story bettAr!
Old Sep 8, 2003 | 11:35 PM
722ish's Avatar
ASM FTW!
i have the stock wheel noticed something weird
i checked the underhood fuse.... popped... so i replaced it
this is the horn/hazard fuse, so it tells me... it wasnt popped before mind you...
i replaced it, boom, 4 ways worked... horn NO... washed the car, with NO high pressure water anywhere, just a typical garden hose... now, the hazards are done for again... guess burning the car is probably a good idea now... plus, i have a pesky rattle, this stuff really bothers me...
11 SWP STI sedan
Old Sep 9, 2003 | 06:19 PM
TampaWRX's Avatar
danse
Mark, I think you've got gremlins.
Seriously, you need to get underneath the steering column/dash and have a look around. I wouldn't recommend taking anything apart, but start looking around for any frayed or crimped wiring, evidence of shorts, etc. Burning up the fuse means something is wrong in the electrical delivery...finding it could be a real bitch though.
“You will never do anything in this world without courage. It is the greatest quality of the mind next to honor.” - Aristotle (384 BC-322 BC)
Want to know what the war in Iraq is really costing America? Click here
Old Sep 12, 2003 | 01:48 PM
TheotherJoe's Avatar
or like i had said before when alan moved your horn when installing the radiator haha he might not have covered a wire or something all the way and when it gets wet its shorting out.
Old Sep 12, 2003 | 07:10 PM
Skeet's Avatar
4x4
i got a couple question...
are carbon fiber hoods worth the money?
do better radiators add HP
Old Sep 16, 2003 | 10:15 PM
yes radiators can add A hp. maybe minimal power if lucky only because it is keeping you cooler but i still doubt that.
carbon fiber hoods are not much less then the factory alluminum hood.
I thought in a previous post you said your car was stock? MAYBE you should leave it like that.
and dont forget stickers 10 hp for every sticker!!!!!!!!!!!!!!!!
Old Sep 16, 2003 | 10:19 PM
722ish's Avatar
ASM FTW!
dollar and 3/4, all better! horn wire was pinched in my "radiator"
11 SWP STI sedan
Old Sep 19, 2003 | 01:51 PM
beep beep.
