S13/14 240sx parts & SR parts RB20/25 manifold
Old Jan 10, 2011 | 05:52 PM
3SVERIZON's Avatar
GTE is out of bussiness ^
Default S13/14 240sx parts & SR parts RB20/25 manifold
i have some stuff that has been laying around and its time to clean the storage garage... all prices are starting, im not looking for low balling assholes to waste my time, but prices are OBO im willing to work with it some...
*******ALL PARTS ARE IN CLEARWATER********
i will add more as i find more!
used in good working condition SR20DET RWD Starter $100
two piece S14 manual DRIVE SHAFT $50
a SOHC KA24 MAF untested but i wouldn't of saved a bad maf ? $10 and ill refund it if its bad..
rubber S13 SR20DET maf -turbo inlet hose $25
S14 SR20DET uncut Wire harness & ECU in great condition. ECU code WC which is the rom-tunable ecu. as a package $450
Brand new OBX stainles steel turbo header for the Nissan Skyline RB20DET and RB25DET engine. This manifold is for a 3-Bolt Turbo application, Wastegate oulet is tapped into a dual source prior to the collector to allow for best possible boost control and reduce boost creep. Manifold is made from 321 stainless steel for durability and should provide years of usage and enjoyment. cost $325 on ebay( OBX Exhaust Turbo Manifold Header Skyline RB20 RB25DET - eBay (item 160480356920 end time Feb-09-11 11:07:12 PST) )
ill let it go for $220
Sean Kriner
Crew Cheif / Lead Mechanic
*RACE CAR FABRICATION
*WELDING
*ENGINE BUILDING
*WIRING SERVICE
2002 Lexus IS300
2001 Lexus IS400
2000 F250 7.3 diesel
1990 Celica GT FOUR
Old Jan 10, 2011 | 06:06 PM
3SVERIZON's Avatar
1992 SC300 2JZ-GE engine no trans (run-able) with aftermarket cams not installed harness, ECU , MAF , IGNITOR, COIL, STARTER, FLEXPLATE, ALT, PS PUMP.. and such it has a JDM Aristo front sump oil pan and a S13 engine cross member to swap into 240SX $1000
Sean Kriner
*WELDING
*ENGINE BUILDING
*WIRING SERVICE
2002 Lexus IS300
2001 Lexus IS400
1990 Celica GT FOUR
Old Jan 11, 2011 | 02:29 PM
3SVERIZON's Avatar
Sean Kriner
*WELDING
*ENGINE BUILDING
*WIRING SERVICE
2002 Lexus IS300
2001 Lexus IS400
1990 Celica GT FOUR
Old Jan 27, 2011 | 05:09 PM
3SVERIZON's Avatar
buy my parts!!!
Sean Kriner
*WELDING
*ENGINE BUILDING
*WIRING SERVICE
2002 Lexus IS300
2001 Lexus IS400
1990 Celica GT FOUR
Old Jan 28, 2011 | 04:33 PM
3SVERIZON's Avatar
I'ts from a non- ABS car,but the abs diff is only about 12mm longer and as far as i can remember the driveshaft part number is the same for either car, there is about an 25mm tolerance for the tail-shaft to slide on non abs cars and 13mm on abs cars.
i kept a few drive shafts in stock when i had my shop, back then they were being sold for 150$
it is in two pieces right now to save space.
Sean Kriner
*WELDING
*ENGINE BUILDING
*WIRING SERVICE
2002 Lexus IS300
2001 Lexus IS400
1990 Celica GT FOUR
