4g63 420a 89-06 parts block head cams injectors eclipse talon gst tsi awd 2g 1g dsm
Old Dec 12, 2012 | 10:37 PM
IllegalModz's Avatar
Default 4g63 420a 89-06 parts block head cams injectors eclipse talon gst tsi awd 2g 1g dsm
this is a list of stuff. if its not here it does not mean i dont have it.
i have to much stuff to list.............................................
please call me at 8887651500 for any parts or service thanks.
4g63 Mivec Head 2006 without cams $500
4g63 1g 2g kelford 272 cams $350
4g63 1g 2g bc 282 cams $250
4g63 stock cams $25 set
420a stock cams $25 set
4g63 6 bolt brand new Wisco pistons eagle rods block $1200
4g63 awd 23 spline Transmission built $1100
420a manual transmission 95-99 $250
4g63 bare head resurfaced $200
420a bare head resurfaced $200
420a block $150
420a used clutch $25
4g63 flywheel 7 bolt fwd $35
4g63 3 inch downpipe $50
4g63 Awd Subframe 2g eclipse all suspension diff rear $800
4g63 block $160
4g64 block $150
420a valve cover $50
4g63 valve cover $65
420a set used rods $50
4g63 set used rods $65
420a oil Pan $50
4g63 7 bolt oil pan $75
4g63 6 bolt oil pan $85
4g64 crank std $100
4g63 6 bolt crank std $200
4g63 stock intake 7 bolt $35
4g63 stock intake 6 bolt $45
4g63 compressor bracket $20
4g63 power steering bracket $15
4g63 rear main seal housing $15
4g63 oil filter housing/cooler $30
4g63 timing belt crank gear $20
4g63 turbo exhaust manifold $35
4g63 crank pulley $25
4g63 fwd dust shield $15
4g63 water pump pulleys $15
eclipse 95 front bumper $15
eclipse 95 rear bumper $15
eclipse 97 right and left door $25 each
98 eclipse hood $50
evolution 8 9 act pressure plate $125
evolition 8 awd transmission $1800
750cc fic injectors $180
950cc fic injectors $210
1350cc fic blues $240
Fpr $100
4g63 act pressure plate 2100 $50 2400 $75
4g63 solid motor mount $35
420a soldid engine mount $25
eclipse 96 rear hatch $65
Leather seats sets Not in the best of shape $50 pair of seats 95-99 ecipse
4g63 injector resistor $50
4g63 ignition modual
4g63 coil pack $25
420a coil pack $20
420a starter $30
4g63 starter $40
95-96 head lights set $40
95-99 rear tail lights set $30
95-99 eclipse dash $75
steering wheel air bag $80
dash air bag $75
steering wheel $20
side skirts cups also talon skirts
eclipse mirror $30 each side
Old Dec 13, 2012 | 04:57 PM
Boost Demon's Avatar
Are the short blocks 7-bolt, or 6-bolt? Any grey or black dash boards? Thanks and good luck with your sale.
Old Dec 13, 2012 | 10:44 PM
hey buddy its been awhile, yeah I got a 6 bolt with your name on it. You got a 2g didn’t you? I think I got a grey for sure, You should stop in the shop sometime. Just got done building a 06 Evo Mr Edition Stroker Setup. It made great power after the break in. Today I just got done putting together another 2.4 for this 06 Evo Se edition also in the shop. Also working on a 09 Chevy SS and about half a dozen other build. Business is good and we have a kid on the way. anyways you still have our number if you want that 6 bolt we could use the money. thanks man.
Old Dec 15, 2012 | 05:01 AM
Congratulations, that's great! I had to use "What to Expect When Expecting" as my Haynes manual. I'll see what block, or dash you have available early next month.
Old Dec 21, 2012 | 08:03 AM
Cruzanspeed's Avatar
6 bolt driver side mount bracket & transmission mount bracket needed
IllegalModz
For Sale/WTB Mitsubishi
Jul 15, 2012 02:13 PM
IllegalModz
30
Jul 15, 2012 01:39 PM
Styl129
Dec 13, 2011 10:41 AM
ImportImageRacing
Feb 12, 2006 05:50 PM
