P8R, Crower, Integra, and more OEM parts
Old Apr 30, 2014 | 08:02 PM
Jeffaome's Avatar
Default P8R, Crower, Integra, and more OEM parts
Message me if you're interested in anything or want pics! Prices DO NOT include shipping
Located in Orlando.
OEM optional Stanley side markers - Sold
P8R head with Rocket Motorsports Valvesprings - $340
Specs are 45lbs closed and 135lbs open (0.500")
-The valvesprings, seals and retainers were replaced
-I can include the stock valvesprings if wanted.
Crower 403-2b cams - $230
-These cams are intended for a NON-VTEC LS/B20
-They are slightly used,
Integra Front and rear calipers - $100 with rotors/$170 for just calipers
-Rear calipers are NOT seized as is so common with Integras
Integra rear dust sheilds - $5
Integra 14mm rear sway bar - $20
Misc items: - $4 ea
List:Yamada oil pump w/ bolts
Water pump w/ bolts
OEM flywheel bolts
Oil pickup hardware
Ls Oil girdle w/ bolts
Crank seal cover with bolts
Crank sensor with hardware
Knock sensor
Oil pan bolts
Ls Lower timing belt cover
Ls upper timing belt cover
With hardware
Oil dipstick
Random mount with hardware
Drivers side b series mount
Alternator mounting bracket
Timing tensioner spacer and bolt
Ls headstuds
OEM Integra springs and shocks -$80
-The rear shocks were blown and replaced with Monroe shocks from Advanceauto
Integra shock forks - $20
Integra stock mounts (fit EG)
-Trans mount is torn, these are a great candidate for someone who wants to window weld the mounts (ghetto solid mounts!)
Strongarm Integra hatch shocks - $5
-Not the strongest, but they work
Russel stainless steel clutch line - $10
-This line replaces the soft rubber line from the hard line that leads from the master to the slave
NA b-series valve cover - $20
LS cams (No gears!) - $10
LS cams with gears - $25
94-01 integra trailing arms -$30
94-01 rear LCAs- $20
94-01 manual integra mounts - $10
rear mount is torn
OEM b series alternator with AEM trupower pulley - $80
Used PHK pistons/LS rods - $60
[ATTACH=CONFIG]203799[/ATTACH][ATTACH=CONFIG]203800[/ATTACH][ATTACH=CONFIG]203801[/ATTACH][ATTACH=CONFIG]203802[/ATTACH][ATTACH=CONFIG]203803[/ATTACH]
Old May 1, 2014 | 12:19 PM
Jeffaome's Avatar
Pics added. Ask me if you want to get a picture of something!
Old Aug 16, 2014 | 02:46 PM
CCFM563's Avatar
Have you sold the P8R yet?
Old Aug 31, 2014 | 06:30 PM
AXEL's Avatar
Still got the head?
Jibin
For Sale/WTB Honda & Acura
7
Mar 31, 2014 06:04 PM
rodbearing1320+
Oct 14, 2010 05:01 AM
TonyBHS
Apr 21, 2009 11:58 AM
