-dream Come True All Parts(major Steal) $20 Bucks Thats It Pick Up Only!!! First Come
Old Apr 18, 2009 | 01:46 PM
diamond101's Avatar
Default -dream Come True All Parts(major Steal) $20 Bucks Thats It Pick Up Only!!! First Come
THESE ARE ALL STEAL OF A DEAL
(ENJOY)
(PICK UP ONLY)
HERE IS THE NEW IMPROVED UPDATED LIST.
I DID INVENTORY THIS MORNING ON WHAT I HAVE LEFT.
1.sick billet aluminum screw on shift knob-(b/m) retail$100)-$
1 ls THROTTLE BODY(NO TPS) X2-PRICE IS EACH
2.ls FUEL RAIL- NO REGULATOR
3.LS CAMSHAFTS
5.LS,B16,GSR-NGK-PLUG WIRES-$10
8.FULL USED GSR V/T-ALL OEM-
SPRINGS,RETAINERS,ROCKERS WHOLE SET.-$20
9.FULL LS (HEAD) ROCKER SET WITH CAM CAPS N BOLTS-$10
12.GSR WATER KNECK ASSEMBLY-$10 EACH X2
13.DRIVER SIDE KNUCKLE HUB ASSEMBLY -$30-bare
13 GSR DRIVER SIDE CALIPER-$20
14.GSR CLUTCH PEDAL-WITH SENSORS-
\PERFECT FOR 5SPD SWAP.-$10
16.obd o ls ecu
15.Z6 VTEC SELANOID-
18.vtec preasure switch only-gsr-$-very hard to find-when they go bad
21.EF DIGI SI DASH-MINT-$
23.DA DASH-CLEAN-$20
25.DC2 REAR INTEGRA PANELS BLACK-$
26.FULL GSR ABS SYSTEM
BRAND NEW MASTER CYLINDER 5SPD-$
28.full GSR underdash ac system-$
.GSR HEADLIGHTS-$30-94-97 HALO OEM
28.EG HEADLIGHTS CLEAN-$
31 sohc starter-20
30.NEW AC COMPRESSOR
SOHC AC BRACKET-$SOHC
24.CRX TRUNK COVER-$ 6X9 HOLES ARE CUT INTO IT FOR SPEAKERS
32. CRX TRUNK REAR PANLE-
33.SOHC TIMING COVERS-$
34.few eg MOTOR MOUNTS-$
39.STEELIES 14INCH-2-4 not sure-$20 EACH
40.CLEAN Y8 VTEC BLOCK-COMPLETE-MINUS INTERNALZ-
41.Y8 CLUTCH KIT-STAGE 1-SOHC-$
42.Z6 FLYWHEEL-$
eg shift linkage only-UPPER-$
43.HF TURBO MANI-$ NO PLATE
44.SOHC CAT CONVERTER FOR CR
X-$ not hacked-sells for easy 100 at junkyard
z6 oil
pan-Z6-$
z6 valve cover(giant vtec emblem on v/c mint)-$
HERE IS BUNCH GREAT PARTS CHEAP AS FUCK PLEASE TAKE THEM ALL NEED GONE.
ANY INTREST CALL AND PICK UP ONLY
(UNLESS YOUR BUYING A CAR)
727-364-6274 CALL ME FIRST COME FIRST SERVE
Old Apr 18, 2009 | 02:08 PM
rangcrx's Avatar
engine building &best
i will take all 8 innner gsr valvesprings if you will sell them
i love AUTOZONE
Old Apr 18, 2009 | 04:03 PM
diamond101's Avatar
pmd bump
Old Apr 18, 2009 | 04:42 PM
hondaking625's Avatar
DB1 FTW!!
pm me location
Old Apr 19, 2009 | 07:50 AM
Foxdecoy's Avatar
do you have a crank for a d16z6
Old Apr 19, 2009 | 07:56 AM
CIVICDESOL_809's Avatar
bro send me pic about the headlight thank
Old Apr 19, 2009 | 10:58 AM
ImPortZracingshop's Avatar
joshua aka. Jayvee..thief
no crank/n there are no pics of any headlights all of them are mint.
Old Apr 19, 2009 | 04:08 PM
freakasis's Avatar
got a pic?
got the rear one that bolts to the frame rail?
good? how many miles on it? got the throwout bearing and everything?
"Black people can't be racist" - Some black guy.
Old Apr 19, 2009 | 04:56 PM
JDM son!'s Avatar
Professional Hustler.
T T T
MONEY IS THE MOTIVE.
Old Apr 24, 2009 | 04:52 AM
diamond101's Avatar
ttttttttt
