For Sale/WTB GM - Buick, Cadillac, Chevrolet, Pontiac, Saturn Strictly GM related For Sale/WTB
lots of sbc performace and chassie parts
Old May 10, 2009 | 10:48 AM
rodbearing1320+'s Avatar
Default lots of sbc performace and chassie parts
sbc canfeild aluminum heads 2.10 1.625 valves withh 220cc runners and 64cc chambers complete with 7/16 studs guild plates 700 lift solid roller springs and molly reatiners 850.00
sbc brodix hv100 4150 intake 395.99 new in perfect shape 250.00
package deal heads and inatke 1000.00
400sbc 4 bolt block fresh from machine shop 60 over line bored decked new cam bearings and freeze plugs are hard blocked over 450 in machine work but went to a aftermarket block 400.00
lunat 640 645 solid roller with macthhing roller lifters only 20 passes 300.00
950hp race carb worked by the carb shop screw in air bleeds jet extensions and no power valves 975.99 new 450.00
355 race short block 4 bolt block callies dragon slayer 4340 crank calies 4340 h beam rods 13.8 to 1 brc forged pistions fluid damper and sfi sly wheel meiling hv pump and moroso 7qt drag pan motor went 8.90 im my altered with the canfeild heads lifted above. all balanced and clearanced when assembled has about 75 passes on it 1500.00
1800.00 with roller cam and lifeters and crane dual roller cahin
msd pro billet distribtor 125.00
powerglide 8" race converter 4600 to 5200 stall tci converter 300.00
350 scat 2 peice rear main seal cast crank standard standard and 30 over flat top pistions and x rods with arp bolts needs one pistion 200.00
narrowed ford 9" 32 inches from backing plate to plate art pro series 4 link and wishbone and bear centersection ready to build and coil overs 750.00
no axles or gear 4 link and wishbone were 700 dollars alone have all bolts and heims joints was building for a s-10
m/t 18.5 by 29.5 by 15 micky thompson sportsman tires almost new 350.00
any questions please give me a call have lots of other parts in the shop let me know if u need anything 813-299-0096 david
Old May 10, 2009 | 11:05 AM
Na306StAnG's Avatar
Flowmaster nut swinger
Bump for some great deals!!
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old May 12, 2009 | 06:38 AM
bump make some offers and they might be yours
Old Jun 4, 2009 | 04:50 PM
nightmare306's Avatar
are these heads still available???
