Built 4.6 Turbo Motor Tranny Turbo Kit
Old May 18, 2007 | 08:17 AM
gotboost30's Avatar
Default Built 4.6 Turbo Motor Tranny Turbo Kit
You are looking at a complete engine, transmission and turbo system for a 2wd Expedition, Lightning, F-150 or Navigator. The engine and transmission will also work in Mustangs but the turbo system will not fit the car. I built this setup for my Expedition. It was recently completed but I am forced to sell it for financial reasons.
Everything is new. The engine has been broken in correctly and currently has just over 900 miles on it. The oil has already been changed three times during the break-in period. The engine runs cool and quiet and has not been abused at all. It has never been ran with more than 5 psi of boost. All the details are listed below. I am sure I've left out a few parts in the description. I've invested a great deal of time and money into this build. I hate to have to sell it but there's nothing else I can do. I will be happy to answer any questions.
This auction is for the parts listed only and does not include the vehicle. The complete vehicle can be purchased as it sits for additional money. Contact me if your interested.
$10,000 I can be reached at 727-365-2290. Please call with any questions.
Dyno Video Link: 1st Dyno Run, 528 Miles on Engine, 5 PSI Boost Level, Driveability Tuning Only http://s189.photobucket.com/albums/z192/turboxpodition/?action=view&current=DSCN1980.flv
4.6 Mustang GT Iron Engine Block
-Cleaned, Decked, Bored .020 over, Line Honed
-Cryo-Treated Main Caps and Main Bolts
-Clearanced for Forged Steel Cobra Crankshaft
-Cryo-Treated
-Federal Mogul Main and Rod Bearings
4130 Forged H-Beam Connecting Rods
-Cryo-Treated
Manley 2618 Alloy Forged Pistons
-18cc Dish
-Cryo-Treated Pisons and Wrist Pins
-Sealed Power Piston Rings
Fully Balanced Rotating Assembly
Cobra DOHC Tumble Port Cylinder Heads
-Ferrea Valves
-Comp Cams Valve Springs and Retainers
-Fresh Valve Job and Cleaning
-Stock Camshafts
ARP Head Studs
Cometic Head Gaskets
Cryo-Treated Oil Pump Gears
New OEM Ford Timing Chains, Tensioners and Guides
New OEM Ford Gaskets
-Timing Cover
-Valve Covers
-Spark Plug Tube Seals
-Oil Pan
-Intake Manifold
-Front and Rear Main Seals
Sullivan Intake Manifold
Sullivan Fuel Rails
Accufab Single Blade Throttle Body
42# Lightning Fuel Injectors (used for break-in)
Aeromotive Fuel Pressure Regulator
Powder Coated Intake, Valve Covers and Timing Cover
Meziere Electric Water Pump
FAL Bolt-In Dual Electric Fan Assembly
New Cobra Alternator
Built 4R70W Transmission
Lentech 9.5" 3500 Stall Converter w/ Lock-Up
SFI Approved Flex-Plate
ARP Flex-Plate Bolts
Two B&M Transmission Super Coolers w/ Steel Braided Lines
Custom Turbo System
-Master Power T70 Turbocharger
-Ceramic Coated Turbine Housing
-Turbonetics Aluminum Velocity Stack
-2 1/4"-2 1/2" Turbo Inlet Tubing, Ceramic Coated
-3" Downpipe, Ceramic Coated
-Custom Headers, VHT Coated
-Tial 38mm Wastegate
-Wastegate Recirculation Tube, Ceramic Coated
-3" Polished Aluminum Intercooler Tubing
-Polished Front Mount Intercooler
-Tial Blow Off Valve
-High Quality Silicone Connectors
4" Exhaust System From Downpipe to Rear of Truck.
Lightning Mass Air Meter
PICTURES
http://i189.photobucket.com/albums/z...n/DSCN1968.jpg
http://i189.photobucket.com/albums/z...n/DSCN1941.jpg
http://i189.photobucket.com/albums/z...n/DSCN1975.jpg
Old May 22, 2007 | 08:47 PM
gotboost30's Avatar
Old May 23, 2007 | 05:17 AM
Na306StAnG's Avatar
Flowmaster nut swinger
Bump for a bad ass fucking truck. Seen the truck the other day.
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old May 23, 2007 | 07:21 AM
gotboost30's Avatar
Old May 23, 2007 | 07:23 AM
gotboost30's Avatar
Thanks
Old May 23, 2007 | 08:38 AM
ChrisN1313's Avatar
How much for the whole truck.
Old May 23, 2007 | 06:48 PM
gotboost30's Avatar
Old May 23, 2007 | 07:51 PM
gotboost30's Avatar
Old May 24, 2007 | 06:40 AM
gotboost30's Avatar
Originally Posted by gotboost30
Old Jun 1, 2007 | 06:21 AM
gotboost30's Avatar
