For Sale/WTB Chrysler, Dodge, Plymouth, Eagle Strictly Dodge related for sale/WTB
WTB: Neon DOHC Longtube Header, '95 DOHC Harness & Parts...
Old Dec 24, 2008 | 05:32 PM
Ahhhh Nick!'s Avatar
Out Of Towner
Originally Posted by got_bst?
if u built it you should go past the 220 line i'm guessing around 240-250 should be doable since it's a 2.4 compared to the 2.0
Exactly how much research have you done?
Old Dec 24, 2008 | 05:54 PM
got_bst?'s Avatar
Passed you
jst sayin i saw a guy who " said " his made 300 with spray so i'm guessin it would be possible on to hit 250 w.o spray lol
budget is key
it can be done
if a 2.0 can do it so a 2.4 should be able to pack more lemme do some research so i can shove it in ur face lol
if not w.o spray... oh well then i'm wrong lol
for example the reg 2.4 such as in the caliber rt has 175hp
if a honda motor with 160 hp can be built to 250 + while na then so can ur 2.4
Old Dec 25, 2008 | 01:23 AM
Out Of Towner
budget is key
it can be done
2.4 in our cars stock will put us around 165hp. I'm not paying anything for the complete block & head. Here's everything it takes to make 200whp with a n/a 2.4:
Required Parts
Camshafts: Crane 22 or bigger, or a set of the crower custom grind cams (like 3 sets made?)
Valve Springs: Crane or Crower, Crower preferred.
Retainers: stock is fine, titanium if you want to be fancy.
Valvetrain: PT or 2.7 Rocker Arms, PT Lifters
Exhaust: at least 2.5", 3" is optional, exhaust dump for the track is a good choice or if you want a quiet setup using stock piping.
Intake Manifold: DOHC Intake Manifold can do it.
Header: Longtube Header, at least 21" long primaries, in the area of 27-30" is fairly common.
Intake: Cold air intake of some sort. Iceman, 2.5" piping, 3.0, etc
Throttle Body: at least a ATX 52mm, 60mm+ is preferred.
Cylinder Head: Full Race P&P. Regular DOHC, PT, or SRT-4.
Fuel System: 24 lb injectors with 58 PSI Regulator, or 30 lb'ers with stock 49 PSI Regulator. Adjustable FPR is optional and best choice.
Fuel Pump: Walbro 255 Highly Recommended.
PCM: MPP DOHC PCM at minimum. AFX or MS optional.
Tuning Hardware: S-AFC or Adj. FPR at minimum. MS optional.
Clutch: at least PT Clutch. Stock SRT-4 or stronger is optional.
Pulley: Underdrive Pulley
Cam Gears: Adjustables basically required for tuning. AEM, Fidanza, UR, etc.
Other optional things to do:
Remove the Balance Shafts
Crank-Scraper
Windage Tray/Baffle Kit
Aluminum Flywheel
Decking of the head (0.020-0.045")
Stainless Steel Valves, oversize won't hurt, but might not be much gains.
Aftermarket Box Manifold, etc. (AMM, Blackdog, etc)
Other Information:
The header will need at least 1.75" primaries.
A merge collector is highly recommended, if not required.
Old Dec 25, 2008 | 04:46 AM
got_bst?'s Avatar
Passed you
that's alot for so little well Gl nyway
