NEW Bullseye Power Turbochagers - Billet/Batmowheel!
Old Apr 11, 2011 | 12:41 PM
S&R performance's Avatar
Default NEW Bullseye Power Turbochagers - Billet/Batmowheel!
Bullseye Power has just raised the bar, AGAIN! Bullseye Power now has a complete line up billet S300 turbochargers that can help you reach power levels that are hard to get in a turbo frame this size.
Bullseye Powers Billet Technology has been really performing and now, they've added the option of their new, BatMoWheel Compressor Technology!
The new BatMoWheel Technology enhances high pressure spots on the compressor with raised inducer blades that are designed to essentially grab more air to produce more power. That allows for greater flow without the downfalls of running a larger compressor.
Check out a side by side comparison to the BEP Performance Billet Compressor.
S362 Billet 6 Blade Turbocharger w/ BatMoWheel Technology:
The new S362 Turbocharger is designed for those looking to make some great, streetable power. The S362 Billet Compressor can net you over 500whp on pump gas with a real great power band. It's 6 Blade compressor will allow for better response!
Bullseye S362 Billet Turbo
Regular Price: $1600
Our Price: $1499 Shipped
S366 Billet 6 Blade Turbocharger w/ BatMoWheel Technology:
Bullseye Power S366R Billet is a power maker, built to be used to it's full potential and maximize performance. It utilizes Bullseye Power's 5.5" Race Cover with the 9.5" Back Plate.
Bullseye Power S366R Race Billet Turbo
Regular Price: $1,850
Our Price: $1,749
S372 6 Blade Billet Turbocharger:
The Bullseye Power S372R is the real deal. This is the turbo that will net you big power on pump and even more with a race fuel. It's extended tip compressor technology and advanced Billet Aero will perform like a bigger turbo without the added lag. If you're looking for a 72mm turbocharger, this is the one for you.
Bullseye Power S372R Race Billet Turbo
Our Price: $1,749
S375 6 Blade Billet Turbocharger w/ BatMoWheel Technology:
The Bullseye Power S374 Billet Turbo is good for a true 1000hp build. It's 74mm compressor utilizes the very latest in performance Billet Compressor Wheel technology and retains the world renowned Extended Tip Technology. What does that mean to you? It means that you get greater flow and performance without needing a bigger compressor that would bring great lag and delayer response.
Bullseye Power S374R Race Billet Turbo
Regular Price: $1850
Our Price: $1,749
S376 7 Blade Billet Turbocharger:
The Bullseye Power S376 Billet Turbo is good for a true 1120hp build. It's 76mm compressor utilizes the very latest in performance Billet Compressor Wheel technology and retains the world renowned Extended Tip Technology. What does that mean to you? It means that you get greater flow and performance without needing a bigger compressor that would bring great lag and delayer response.
Bullseye Power S376R Race Billet Turbo 7 Blade
Regular Price: $1950
Our Price: $1,799
S378 7 Blade Billet Turbocharger:
The Bullseye Power S378 Billet Turbo is good for a true 1150hp build. It's 78mm compressor utilizes the very latest in performance Billet Compressor Wheel technology and retains the world renowned Extended Tip Technology. What does that mean to you? It means that you get greater flow and performance without needing a bigger compressor that would bring greater lag and delayer response.
Bullseye Power S378R Race Billet Turbo 7 Blade
Regular Price: $1,950
Our Price: $1,799
S380 7 Blade Billet Turbocharger w/ BatMoWheel Technology:
The Bullseye Power S380 Billet Turbocharger is capable of making 1200hp and delivering performance and reliability in a single package. It really is a great turbo that will hold up to the greatest of race demands and perform time after time.
Bullseye Power S380R Race Billet Turbo 7 Blade
Regular Price: $2,000
Our Price: $1,899
S383 7 Blade Billet Turbocharger:
The Bullseye Power S383 Billet Turbocharger is the big daddy of the S300 platform. This turbocharger is rated at 1250hp and will provide you a consistent, reliable and PERFORMING turbo that you can build around.
Bullseye Power S383R Race Billet Turbo 7 Blade
Regular Price: $2,050
Our Price: $1,899
We've got the complete collection of Bullseye Power Turbochargers available! We will not be undersold and we hope to get a chance to work with you and help you pick the right turbo for your particular build.
Old Apr 12, 2011 | 10:25 AM
Default S200 Framed Bullseye Power Turbochargers
Bullseye Power's S200 turbochargers are power houses and perform very well on 4 cyl applications. DSM, EVO, Suby, Honda and more, I've used these on all sorts of builds and hitting less than 500whp would be a head scratcher. Check out these great S200 sized Turbochargers and PLEASE, feel free with any questions that you may have. Extended Tip Technology allows for greater air flow with smaller wheels. In other words, you get the flow of a bigger wheel without the slower response typically associated with the bigger wheel.
Bullseye Power S200 Turbochargers
Bullseye Power S256 Turbo:
The S256 is a turbo that packs a serious punch. I first used one of these on an EVO and made over 530whp on pump gas with similar torque numbers. It hits like a champ and is built like a tank! Super resilient and a great turbo to build a performance platform around. Extended Tip Compressor technology really shines with this bad boy!
Borg Warner S256 Turbocharger
Regular Price: $1,200
Our Price: $1,099
Bullseye Power S259 Turbo:
The S259 is a great alternative to something like a 35R. It hits very hard and makes big toque. It's a turbo that I've reached right under 600whp on pump gas with! It's a killer turbo in a relatively small package. Great for Bolt on DSM or T3 applications.
Regular Price: $1,380
Our Price: $1,279
Bullseye Power S259 Billet Turbo:
If you're looking for a responsive, big pump gas power turbo, well, you have found EXCALIBUR. This Billet, 59mm turbocharger makes some of the best torque and hp numbers that we've seen in a turbo this size. It's transient response is amazing, it doesn't drop off in the top end and will hold up to just about anything you throw at it.
Bullseye Power S259 Billet Turbocharger
Regular Price: $1,680
Our Price: $1,499
The S200 line up is ideal for a real big pump gas power, 4 cylinder setup! They are also awesome for a well setup, twin turbo setup. We want to work with you so please let us know of any questions that you may have about these or any other of the many turbochargers that we offer.
Thank you for your time.
Old Apr 18, 2011 | 09:46 AM
Power, Reliability & Performance, all in one package! Let us know what questions you have about Bullseye Power Turbochargers!
Old May 4, 2011 | 05:52 AM
These have been a big hit with the import and domestic scene! Let us know what questions you have so we can help get you the best turbo available!
Old May 23, 2011 | 12:27 PM
Default Check out the new exclusive compressor covers to the BatMoWheel Turbochargers!
These new compressor covers by Bullseye Power will allow for 4% greater air flow to really maximize the performance of your new BMW turbochargers.
Ready for a new home!!!
Again, you can check out the entire line up of these awesome turbos on our website!!
S300 Turbochargers
Old Jun 3, 2011 | 08:25 AM
OH YEAH!
S372 BatMoWheel w/ SS Lite Weight V Band Turbine Housing!
This one is going on a built Honda that will be doin work!
Kirk
Boost Lab Turbo & Fuel Injection
8
Apr 15, 2011 08:45 AM
Kirk
Mar 31, 2011 03:08 PM
Kirk
4
Feb 13, 2011 12:23 PM
Alpha
Induction Performance
Jun 1, 2008 02:01 PM
