SE Region: Block Rebuild / Drivetrain Services / Timing & More!
Old Nov 17, 2010 | 07:29 AM
S&R performance's Avatar
Default SE Region: Block Rebuild / Drivetrain Services / Timing & More!
S&R performance is THE SHOP to go to for all of your Subaru needs in the region. We build and Rebuild more Suby's than anyone and we're very happy to have this place in the community.
Got Rod Knock, Piston Ring Land Failure?
We offer various levels of rebuilds and replacement motor builds! We use CP, Manley, Wiseco, Cosworth and more to offer you the very best in build internal parts.
Sample Service Deal:
Remove your rebuildable 2.5L Block
Machine Block (Bore, Hone, Deck)
Rebuild with CP Pistons & Manley Rods)
New OEM Oil Pump
Complete Timing Belt Kit w/ Water Pump
OEM Engine Gasket Kit
ARP Head Studs
Install Rebuild Long Block
$Starting at only $4449! Parts and Labor
No matter what you want to build towards or what kind of rebuild you need, S&R Performance is your one stop shop! We've NEVER had a motor build come back. Check out a few of our "Fun w/ Build Pics"
Hope you guys enjoy the pics. Taylor builds some really great motors and we want to get a chance to build on for you!
Old Nov 17, 2010 | 07:30 AM
We perform clutch and drivertrain services on all kinds of Subaru's. We've done full range of drive train services on all kinds of Subaru's. From a STi drivetrain conversion on an SVX to a simple clutch replacement on a Forester.
Sample Clutch Service:
Competition Clutch Stage 2 Kit
SS Clutch Line
RedLine Light Weight Shock Proof
Flywheel Resurface
Installation
$899
This is just ONE example. We've got some GREAT options from some of the following manufacturers....
We've got some AWESOME add-ons for your drivetrain service, too!
Torque Solution Dog Bone Mount:
Torque Solution Shifter Kit:
Torque Solution Shifter Bushings:
We're here for you, folks. Let us know how we can earn your business.
We can handle your basic timing service and even perform some great upgrades!
Our basic service includes the following:
Gates Racing Timing Belt
Tensioner
Water Pump w/ Gaskets
Small Idler
Coolant Flush
Labor
$529
We can make this service as extensive as you need it to be. We offer quality products from the best manufacturers to make sure that your timing is on point and stays that way!!!!
Old Dec 6, 2010 | 07:27 AM
We are your one stop Suby shop! We build more Suby's than about anyone else in the area. We build it right! Let us know how we can help you!
