Johnny Cash Mustang project
OK do any of you remember JC's old song about his 1959-60=61 Cadillac, where he steals the car from the factory a piece at a time? Well here's the Fox version of it. I race in the FAST series autocross in central Florida, the rules are fairly simple and reasonable, (unlike other groups). So in my quest to constantly run faster than the import crowd, this is my latest offing, a 1987-88-89-90-93 Mustang. I figure I might run it on track days so I might as well put a cage in it,
This is the look we're after..... http://i149.photobucket.com/albums/s...-1/4801_11.jpg http://i149.photobucket.com/albums/s...6870679801.jpg Step 1. Picked up a Mustang from a Tampa Racing member for $50 had some buddies load in on the trailer and then onto the rotisserie. Step 2. start welding up the 15 thousand tiny holes Ford drills all over the engine bay. http://i149.photobucket.com/albums/s...1/DSC_0041.jpg http://i149.photobucket.com/albums/s...1/DSC_0039.jpg http://i149.photobucket.com/albums/s...1/DSC_0038.jpg |
if you need a hand i'm right down the street, nice project to build the way you want from ground up
thats going to be a cool car, good luck
Looks like one hell of a project. Maybe I'll see it out as I plan on doing some Fast events next year.
Finished the engine compartment...
http://i149.photobucket.com/albums/s...1/DSC_0047.jpg http://i149.photobucket.com/albums/s...1/DSC_0046.jpg The backside, where I welded the patches on and caulked the seams http://i149.photobucket.com/albums/s...1/DSC_0048.jpg http://i149.photobucket.com/albums/s...1/DSC_0044.jpg |
OK it's time to build the bracket for the fuel cell, I located some 1 inch square stock, and, using the cell as the template welded up the bracket. I used the cell as the template since they are never perfectly square, this way I can fudge some of the holes in the brackets.
http://i149.photobucket.com/albums/s...1/DSC_0052.jpg I had to "massage" the hole in the cell's box for the plate.. http://i149.photobucket.com/albums/s...1/DSC_0058.jpg Once everything was mocked together, I used some 1-1/2 inch bolts, redrilled the holes through the cell box, and through the bracket. I then welded nuts on the brackets. This was because it is a PITA to access both the nut end and the bolt end when the unit is in the car. http://i149.photobucket.com/albums/s...1/DSC_0056.jpg This is what the complete unit looks like, ready for paint and installation http://i149.photobucket.com/albums/s...1/DSC_0055.jpg I've just been informed that my cage has arrived.............:) |
Here's the finished fuel tank and brackets....
http://i149.photobucket.com/albums/s...1/DSC_0063.jpg ..and here's the Summit racing Allstar cage...... http://i149.photobucket.com/albums/s...1/DSC_0067.jpg The parts in the foreground are the door bars, we probably won't be using them at this time, the autocross doesn't require the bars , (or cage for that matter) so they'll be left out for use in the future for possible track days. I'd rather leave them out since the cage is very heavy and I'm trying to save all the weight I can. That being said, this is definitely the time to install the main bars since the car is stripped down. These are the parts I'll use for now, the main hoop, the halo and the front down tubes, along with the dash bar, the long tubes in the rear are for the rear down tubes. Those bars and the 1/8 x 6 inch plates were sourced from Applied Racing Technology in Clearwater. http://i149.photobucket.com/albums/s...1/DSC_0065.jpg |
Looking good . I'm just glad its being used because it was a nice shell.
Thanks for the extra parts
Ok I started on the cage today, first I jigged up the rotisserie so it was level front to back and side to side. then I placed the main hoop in, leveled it up and measured where the legs of the hoops would go. I used the door bars as jig, resting them on the door sill and tack welding them to the bars, this way I know in the future, if I decide to use them they'll fit.
http://i149.photobucket.com/albums/s...1/DSC_0075.jpg I then removed the cage, and drilled 2-1/4 holes in the floor where the legs will go, then I tacked the 1/8 inch floor plates down and re-installed the cage. (the reason for the 2-1/4 holes will be apparent shortly) http://i149.photobucket.com/albums/s...1/DSC_0074.jpg I welded up all of the seams. As you can see they took some help via a ratchet strap and some "C" clamps to get everything to fit. Once that was done, I removed the (tack welded) floor plates and dropped the cage through the floor in order to weld all of the top seams in the cage. http://i149.photobucket.com/albums/s...1/DSC_0077.jpg Then I pulled the cage back to where it's supposed to be, and replaced the floor plates, this time welding them in for real. http://i149.photobucket.com/albums/s...1/DSC_0076.jpg The almost finished product. http://i149.photobucket.com/albums/s...1/DSC_0080.jpg |
