Sponsored by: CARiD
Turbo Drain Problem Need Suggestions!!
Old Feb 5, 2003 | 11:20 AM
~Boost Freak~'s Avatar
Default Turbo Drain Problem Need Suggestions!!
a have a garrett to4e turbo and the moroso pan the problem is, that the drian bung off the oil pan and the turbo drain line are so close to gether that i can get one to the other without kinking or routing around like the grand canyon... any one have this prob?? or any suggestion on how to fix??
Old Feb 5, 2003 | 01:27 PM
99B16Si's Avatar
i had the same problem so i went to amazon hose and bought some high temp line that actually has strips of metal through it that doesnt allow it to kink. its a little hard to bend but it worked perfect for me. just go there and ask for just that. theyll hook you up and its only like 5-10bucks a foot
Old Feb 6, 2003 | 04:20 AM
i have steel braided #10 (5/ and the angle its on its insanely tight i think i might have got it but won't know till tommorrow (friend punctured radiator on accident ) anyway i use barb fittings insted of the screw on type and it seems to have work will update when finished...
Old Feb 6, 2003 | 01:34 PM
99B16Si's Avatar
Originally posted by "CronicBurn"
steel braided?
no damnit. not steel braided, if it meant steel braided i would have said it... steel braided will still kink. it looks like a normal high temp black silicone line but its got strips of metal through it. just do what i said and be done with it
Old Feb 6, 2003 | 02:06 PM
highoctane's Avatar
Sounds similar to hyraulic hose, rubber hose reinforced with steel wire
Brad
1997 Eclipse Spyder GST 14.1 @ 100 MPH
1991 Eagle Talon AWD (HOW) 11.574 @ 115.29 MPH
1990 Plymouth Laser RS-T (Organ Donor) 13.19 @ 110 MPH
