Sponsored by: CARiD
Dry Shot Mounted,finally...
Old Jan 3, 2011 | 01:51 PM
Paul2281's Avatar
Default Dry Shot Mounted,finally...
Old Jan 3, 2011 | 01:53 PM
Paul2281's Avatar
Old Jan 3, 2011 | 01:57 PM
Paul2281's Avatar
Bought off of ebay and just had to mount it,wire it and plumb to lines....
Installed a B&M adj. FPR and set it at 55psi... Works great....
Had to be able to out run my sons 2door B20 w/gsr trans.....Mine is a B18a1 w/b16 trans.... 4door....
Old Jan 4, 2011 | 12:14 PM
Blackcatn2o's Avatar
nice, i would love to run one but i don't want to take the chance at blowing something up because it is a royal bitch to fix my engine (note that you have to take the whole engine out to rebuild it.)
06 ST Focus/w a Bilstein coilover suspension with some basic engine mods.
Old Jan 4, 2011 | 12:26 PM
x8psycho8x's Avatar
you wouldn't risk blowing something unless you over do it. meaning running to high of a shot on a stock (or any motor). Just because you run nitrous doesn't mean you need a big shot. hell, just start with a 35 shot or something. work to a 50. Don't go crazy with it and you wont need a rebuild haha. Me personally tho, i'd never run a dry shot.
94 accord vtec - traded
95 eclipse gs - blew up
95 eclipse rs - dd
Originally Posted by SayWhaa?
guess some of the guys shes sleeping with isnt too good with the whole pull out method..
Originally Posted by evlonedb
someone needs to tell her its a vagina,not a clown car!
Old Jan 4, 2011 | 12:27 PM
Paul2281's Avatar
Hey I hear you big time....I used to run N20 in my drag bikes and learned how to run it safe...I am running it WAY safe in my B18 motor....As long as I keep the motor retarded a few degree`s,run high octane fuel(100 octane),I am running rich on the fuel too with the adj. fuel pressure regulator........I should be able to run a 50 to 75hp shot without problems....I would REALLY feel safe with a wet kit myself.....But I would have to tap off the fuel gauge adapter on the fuel filter to get my fuel....And then regulate it down to 10 to 15 psi, from there before it gets to the solenoid.....
Old Jan 7, 2011 | 09:23 AM
I knew a guy in Orlando that had the same engine and car (ford focus saleen n2o edition) with a 75 shot from factory, could keep up with stock srt 4 neons until a piece of a valve broke off and shot out the back. Took him more than 3 months to replace one valve, i'd rather go with straight meth kit
Old Jan 9, 2011 | 01:04 PM
Paul2281's Avatar
Ouch>>>>>> Thats not good..................
Old Jan 9, 2011 | 04:39 PM
yea so no on the N2O for me.
Old Jan 10, 2011 | 04:45 PM
Paul2281's Avatar
Hey I hear ya brother....
There`s always a problem with something happening with what ever you go with...
Big motor= stress on internals,rods,valve train,ect.ect
Turbo = high rshared_pm valve train breakage,oil starvation,lean condition
Nitrous = already discussed.........
