Sponsored by: CARiD
do i need anything else to run the turbo on my car?
Old Jun 1, 2002 | 08:38 PM
lostandconfused's Avatar
Default do i need anything else to run the turbo on my car?
alright i am installing a turbocharger for the first time. i would really like to do this correctly. if anyone knows of any sites that could help me with the install, it would be greatly appreciated. this is what i have, or is on its way, please tell me if there is anything else i need before i go ahead with the install.
turbo
manifold(still need, does anyone have one for sale or trade?)
downpipe(am getting made custom because i cant find one)
piping(am getting made custom because i cant find one)
wastegate(delta)
bov
intercooler(side mount)
oil line/ return line
i need a tapped oil pan (does anyone have one or know how to tap one?)
do i need any sensors, or a check valve, or anything. the whole turbo kit is from a eclipse. except for like the piping and manifold and downpipe, the turbo is a tdo5h(i think it is a 14b). my engine is a b17a1, i plan on running 6-8 lbs of boost. my car has all the bolt ons(i/h/e) it also has a fuel pressure regulator, and cam gears. should i raise my fpr, or adjust my cam timing? please any help is greatly appreciated.
If You Can't Beat Them Join Them
"you'll be joining"
Old Jun 3, 2002 | 09:11 AM
stangerang's Avatar
whoopdy fucking do!
your going to need your computer tuned, i can definatly tell you that, you'll also want bigger injectors, FMU, fuel system components like pump, FPR, and all that....
200 points away from a 300
Old Jun 3, 2002 | 09:20 AM
i have a fpr and cam gears, should i adjust my fpr or cam gears? do i really need bigger injectoprs to run 6-8lbs of boost, and the stock map sensor is 2 bar and is capable of handling i believe 12-14 psi. yes i know i will have to get my car tuned. but do i need any other hardware? or bolt ons? im not worrriekd about tuning and fuel management right now. i just want to put it on and make it work fiirst. thankyou for the help.
"you'll be joining"
Old Jun 12, 2002 | 11:28 PM
Matt Vassallo's Avatar
lifelong learner
Do not put anything smaller than an 18G on that car. You will out flow the turbo past 6500 rpm.
rest in peace tim.
Old Jun 13, 2002 | 07:13 AM
i was planning on putting a 14b. i have never heard of out flowing something. i assumed that the turbo would push a steady 6-8 lbs of boost all the way to 7800. why would the boost drop off?
"you'll be joining"
Old Jul 20, 2002 | 12:54 PM
lancerman's Avatar
14b will work rather well for your little project
supports 280whp on a good setup
Old Jul 28, 2002 | 10:23 AM
Turbo GSR Civic 95's Avatar
mattback is right though i had a mitsu TD04-15G on a GSR motor and the car ran almost a half second slower shifting at 7800 as opposed to shifting at about 6800
