procharger+carb
yeah i was reading on prochargers site .to use a elec fuel pump ,but they say......
=========Fuel pump (carbureted applications):
Your fuel pump must be capable of supplying the proper amount of fuel flow at the maximum operating pressure. To determine maximum operating fuel pressure requirement, add your maximum boost pressure to your initial idle fuel pressure.
Example:
(8 psi idle fuel press.) + (10 psi boost press.) = 18 psi max. fuel press.
multiplying this figure by 1.2 (20% safety factor) gives us 21.6 psi
To determine required fuel flow, multiply your total expected horsepower by a bsfc (brake specific fuel consumption) of .65. This will give your fuel flow requirement in 1bs/hr. To convert to gallons per hour, divide this figure by 5.87.
Example:
(500 boosted hp) x (.65 lbs/hr/hp bsfc) = 325 lbs/hr fuel flow
325 lbs/hr / 5.87 lbs/gal = 55.4 gals/hr fuel flow
Therefore, a fuel pump capable of providing a minimum fuel flow of 55.4
gals/hr at a pressure of 21.6 psi is required.
This can be accomplished by an all electric high pressure-high flow fuel pump (i.e. SX #18201, B.G. 400, Magna-Flow 250 or similar type fuel pump) and a return style, boost sensitive fuel pressure regulator (Mallory #4309 or similar). Or by using a boost referenced mechanical fuel pump only (up to 500 hp) or a boost referenced mechanical fuel pump in conjunction with a low pressure electric pump (i.e. Holley blue, Comp 140 or similar).=========
sounds complicated
Example:
Example:
sounds complicated
1972 nova ss
89 240 sr20det
2002 chevy 1500 truck
1972 nova ss
89 240 sr20det
but i know carbs can only hold around 7psi ....but maybe with the presure -insted of vacume on a blow thru ,i might need to boost the fuel pressure to compensate ? idk
1972 nova ss
89 240 sr20det
1972 nova ss
89 240 sr20det
1972 nova ss
89 240 sr20det
1972 nova ss
89 240 sr20det
Have you seen the #'s and times blowthrough cars are making?
Visit my TR Shop Forum
RIP Chester P.Anderson Jr.9/23/05 I love you dad,and miss you very much.
RIP Kevin"Slo SI" 9/13/06,we will miss you homie,time heals wounds but you will never be forgotten
