Sponsored by: CARiD
Deltagate II wastegate question....
Old Apr 4, 2001 | 10:23 PM
TurboRs's Avatar
I have this wastegate on my Rs and right now it limits my boost to around 5psi. I am wanting to install a Blitz SSBC controller i have and set the hi setting higher than 5 my stock internals can handle up to 8 safely but ill only use 7...my question finally is will the wastegate allow me to up the boost or do need a different wastegate all together?
Old Apr 4, 2001 | 11:26 PM
j0lt's Avatar
Well... 5 psi is what the wastegate does by itself and thats controlled by a spring. If you add a boost controller (or bleeder valve) you could have boost from 5 to whatever psi you want. What the controller does is fool the wastegate into thinking that its not getting a full 5 psi so it lets the boost increase. Alternatively you could change the wastegate spring.. but that would raise your minimum boost so its not a good idea. Make sure you add the extra fuel youll need to run higher boost..
-j0lt
Old Apr 8, 2001 | 10:10 PM
TurboRs's Avatar
Thanx for the info guys....yea the fuel shouldnt be a problem the car runs rich naturally and when im at full boost its still on the rich side of my a/f meter plus im using a vortech 12:1 fmu.
Old Apr 17, 2001 | 10:56 PM
_Charles_'s Avatar
formerly 'RiceRocket'
You can actually adjust the Deltagate to run LESS than the spring psi. Dont ask me why it just does. I have a 7psi spring but have run as little as 4psi. With the boost controller the Sky is the limit...I made a 15psi run the other night with the 7psi spring...
Hope this helps
My Blog: www.HotRodCaddy.com
