Sponsored by: CARiD
oil restrictors?
Old Aug 18, 2007 | 06:20 PM
dippincrx's Avatar
save the s.o.h.c
Default oil restrictors?
ive read some info on homemade oil restrictors. basically brazing the hole then redrilling it. now my question is what size drill bit will give lubricate well without give to much oil thanks
Old Aug 20, 2007 | 03:56 PM
manifoldmike's Avatar
i personally wouldn't try to make your own.
they are about $15 at most, however you can find them for a dollar or two if you look hard enough.
Old Aug 22, 2007 | 07:30 PM
dippincrx's Avatar
save the s.o.h.c
to late, did the research. brazed my fitting on the npt side and redrilled it 1/16th opposed the the 1/8th it was not hard at all and only takes a few mins
Old Aug 24, 2007 | 04:27 AM
usually that hole is smaller then 1/16th, but i'm sure that will be okay. i'm not really a fan of brazing.
Old Aug 24, 2007 | 09:40 AM
dippincrx's Avatar
save the s.o.h.c
yea there are .060 but i didnt have a bit that small.
