Too much spray for pump gas??
How much N2O is too much for 93 octane? Would the max hp added for pump gas be different between wet and dry kits? I hope that makes sense :)
Thanks, Frankie |
It dosent... the amount that you can spray is decided by the motor that you are spraying.
The limit is defined by detonation. If it occurs, use higher octane, pull timing, or decrease nitrous delivery. You can't define a set amount of spray for pump gas because higher displacement engines can tolerate more also.
Mike |
i concure
thanks for the help guys :)
Just up the shot 20hp per day, til it blows up... Once it blows up, rebuild, and spray it with 20hp less than what it took to blow it up :D
:tard: :lol: |
i know a 4cyl can handle 200 for atleast a couple passes :lol:
