Sponsored by: CARiD
How do YOU stop the bolts holding the exhaust flange on turbo from backing out?
Old Jun 27, 2005 | 05:06 AM
TNathe's Avatar
Default How do YOU stop the bolts holding the exhaust flange on turbo from backing out?
I'm having a hard time keeping bolts in that hold the exhaust flange on the turbo from backing out. I was debating putting a dab of JB Weld on the corners to hold them in. I have the big bolts that hold the turbo to the manifold tack welded on but I can't do that these little bolts because if I wanna take the exhaust off later I won't be able to get to the welds with a grinder or impact wrench to break them loose. So what do YOU use to keep those bastards snug?
Old Jun 27, 2005 | 05:23 AM
DrDirt's Avatar
Team Geritol Racing
I have lock washers on mine. Never had a problem with them backing out.
YO! Barry! You LOST!
Old Jun 27, 2005 | 12:58 PM
jriggs's Avatar
is better than you™
two words lock tight
we had to use it on my buddies car when he upgraded the toys in it
Old Jun 27, 2005 | 01:01 PM
TNathe's Avatar
loctite doesnt make anything to withstand the heat that I'm aware of.
Old Jun 27, 2005 | 01:08 PM
jriggs's Avatar
is better than you™
we were told to use it and it did the trick, but i will agree with you i didnt think it would work, yet it did. or it could be we torqued the livin shit out of the bolts and got lucky with that on it
in my past history with jbweld it breaks down under heat as well, it just takes a while to do
Old Jun 27, 2005 | 02:09 PM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
Jb weld is good for giving you false hope. The loctite will work fine, just let it dry up.
Do you have any lock washers, or locknuts? They might help you too.
SUCH IS THE RULE OF HONOUR.
Old Jun 28, 2005 | 04:45 AM
TNathe's Avatar
I guess I could try the Loctite bit but I'm skeptical. Thanks guys, I'll see what happens.
Old Jun 28, 2005 | 11:44 AM
Charles's Avatar
Senior Member
Get some of this ( http://www.loctite.com.co/english/products/272.htm ) and use lock washers....... did the job back in my 240 days......
92' Nissan 240sx
02' Honda VFR Interceptor
08' Tundra
