Sponsored by: CARiD
Why does the Turbo Require a Load to create Boost?
Old Mar 6, 2005 | 06:06 PM
Cecil's Avatar
gone fishin
Default Why does the Turbo Require a Load to create Boost?
Example:
I can rev the bike to 7000rpm without a hint of boost when it is on a stand (motorcycle).
vs.
When riding at 7000rpm the boost is active.
Thanks!
Old Mar 15, 2005 | 01:32 PM
NChatch's Avatar
i stepped on my weiner!
also some cars have different set ups as far as vacuum, i know on hondas the BOV stays fluttering, unless under boost and helps drivability
so nuetral revs yields no boost
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Apr 10, 2005 | 07:34 AM
turbo-max's Avatar
The G-14 Classified
7k rpms at no load (i.e. sitting on the stand) = very little throttle input, there fore very little volume of air/gasses flowing through the engine, riding down the road, you open the throttle up alot more and for alot longer, therfore you have alot more air/gasses flowing this creating the said needed flow/heat energy to spool the turbo.
Boost...it's a hell-of-a drug
Old Apr 10, 2005 | 02:59 PM
Josiah's Avatar
Peon on steroids!
under load, the air/fuel mixture is richer, therefore creating far more exhaust gas which is what turns the turbine, which is why you dont boost at idle or cruise...where the a/f ratio is like 17:1, under boost generally the a/f ratio is like 12.5-11:1
Old Apr 10, 2005 | 06:42 PM
turbo-max's Avatar
The G-14 Classified
not too sure about your info there chief
Old Apr 11, 2005 | 05:38 AM
Josiah's Avatar
Peon on steroids!
neither am I....heh, but it true in part anyway, its really a combination of all of the above I would guess, more fuel added makes for an explosion which releases more gasses
Old Apr 13, 2005 | 07:02 AM
Rich's Avatar
Old School.
So, by your explanation of lack of throttle input and time under WOT, if you banged the rev limiter for long enough while its sitting on the stand, you'd build boost? I don't think so.
Load or resistance requires energy to be moved. Its a lot easier to push a ball than it is to push a cube. When the pistons are turning the crank, that is turning the transmission, that is turning the wheel, and moving hundreds of pounds of mass into wind resistance and possible gradients, it requires a considerable amount of energy compared to merely spinning the engine's rotating assembly.
Where does this energy come from? Mostly oxygen, and a little bit of fuel. When this additional oxygen is heated, it expands, like all gases do, and you build pressure between the cylinder and the turbo. The pressure goes the path of least resistance, spins the turbine thus spinning the compressor, and you have boost.
You may know who we are, but we KNOW who you are.
Spyderxl98z24
Aug 31, 2004 10:51 PM
