Sponsored by: CARiD
anyone have something to test for a boost leak???
Old Mar 31, 2004 | 11:11 AM
99B16Si's Avatar
Default anyone have something to test for a boost leak???
im pretty sure i got a boost leak, but i cant find it visually. i was just seeing if anyone had a homeade contraption to test for boost leaks that they can help me out with. i have a 3" inlet on my intake for my turbo also. thanks
Old Mar 31, 2004 | 05:33 PM
NChatch's Avatar
i stepped on my weiner!
dave what you can do, to check for leaks after the turbo, is go to lowes and buy a PVC end cap the same size as your pipe, drill a hole and thread in a fitting for your air compressor and pump some air into it. i know some places have that machine that also pushes colored smoke thru intake tracts to see where a leak is coming from..........only thing that comes to mind......
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Apr 1, 2004 | 07:04 AM
Patrick Wallis's Avatar
try smoke
Old Apr 1, 2004 | 09:41 AM
99B16Si's Avatar
i need to pressurize the system too see if it leaks, so i was seeing if anyone has anything like mike described. and i dont have any pressurized smoke sitting around so i dont think thatll work
Old Apr 1, 2004 | 12:03 PM
Rich's Avatar
Old School.
Just hit up the PVC section at home depot and get yourself a 3" pipe and cap as mentioned. You can pick up a valve stem and insert it from the backside of the cap and glue it in. Use a 3" coupler to mate the testing device to the turbo inlet. I use one similar to this pretty regularly.
You may know who we are, but we KNOW who you are.
Old Apr 1, 2004 | 07:45 PM
99B16Si's Avatar
im broke, i dont have money to waste. i know how to make one, just seeing if anyone has one i can try out for a min or 2
Old Apr 1, 2004 | 07:52 PM
F4A22's Avatar
Old School
We have one at the shop.I dont know what size it is though.Pm nouseforaname on here he might let u come over this weekend to test it.
Old Apr 5, 2004 | 07:06 AM
93supra's Avatar
I have one of those things also if you need help let me know. Oh and if you do make one make sure you have a pressure regulator or a way to control pressure also. I wouldn't shoot 90 psi through your system you might blow off some hoses
