Sponsored by: CARiD
n2o rx7
Old Mar 7, 2004 | 03:01 AM
ProjectRedSuns's Avatar
Default n2o rx7
ok i got a question if you didnt notice from my signature i own a rx7. alright for those that dont know how the rx7 works their is a primary injector before the opening of the intake port. at 3750 rpm the secondary injector which is farther back from the first one turns on. which means more fuel to burn. now my question would be is since this secondary injector exist should i go with a dry system or wet system
Old Mar 7, 2004 | 05:34 AM
same rail. their is two injector for each rotor housing
Old Mar 22, 2004 | 04:12 AM
JonNoH's Avatar
doesnt even lift
I see flying triangles in your future
Pollo is the best admin there ever was ever
Old Mar 23, 2004 | 11:08 AM
Solar Specialist's Avatar
SOLAR-SPECIALIST.COM
Default Re: Re: n2o rx7
Originally posted by `92CXhatch
ok here i have two things for you on this one...
both injectors are ALWAYS firing... what opens at 3750 is the secondary intake ports... it is a butterfly system...
and go with a wet... just cause your motor is useing more fuel doesnt mean it is just being sprayed for fun... it means that it needs it... so in adding nitrous you will need MORE gas... so, WET...
-Keith
Actually both sets of injectors are NOT always firing. At least not on FCs. The primaries are ONLY on until around 3800. Then the secondaries kick in and the primaries cut down on the fuel they add. And the primaries are on a different rail than the secondaries.
Old Mar 28, 2004 | 07:22 AM
psifactor's Avatar
Hello
Isn't using n2o on a rx7 like playing with fire in a big pile of dry leaves?
Heavy car with a 2.5L
Old Mar 28, 2004 | 09:42 AM
If you don't know what your doing. Your not going to safely just slap a N20 kit on and run it like that. Like everything, it should be dyno tuned with a wideband.
