Sponsored by: CARiD
warm or cold air???
Old Jan 7, 2004 | 06:24 PM
dohc_neon95's Avatar
Default warm or cold air???
i need to know if warm weather or cool weather (45-60 degrees) has an effect on nitrous works? Does it makes a difference or not?? someone told me not to spray in cool weather.
And btw its a dry set-up. Any info would help.
18 lbs of boost.....Upsolute chip, Tuned ECU, CAI, neuspeed side intercooler pipe, forge 007p Blow off / D/V, no muffler or resenator, high flow cat, stage 1 clutch, and light weight flywheel...for now...More coming soon. Looking for a Audi TT...
Old Jan 7, 2004 | 08:09 PM
Tony's Avatar
Senior Citizen
Well, engines tend to run a bit lean in the colder air, might be more risky to run a tightly tuned nitrous setup as such would be my train of thought.
10' 1198S
09' Ninja 500R
09' Stella
Old Jan 8, 2004 | 08:18 AM
NChatch's Avatar
i stepped on my weiner!
also air temp would affect how cold your bottle is unless you have a bottle warmer like me, and then NO2 pressure drops severley causing you not to have much of a HP gain form it. buy a heater
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Jan 8, 2004 | 05:55 PM
Tony's Avatar
Senior Citizen
Use a coleman overn as a bottle warmer..you won't!!!
10' 1198S
09' Ninja 500R
09' Stella
Old Jan 8, 2004 | 07:15 PM
..............u r in the air force?? what is ur mos?? Just asking cause I have a leave date for feb 10th...
Old Jan 13, 2004 | 06:56 PM
95Ride's Avatar
Gangsta What
cold cold temp effects thevapors of nitrous so yes it will make a difference but if you innvest the little money for what its worth into a NX bottle warmer it will keep it set at a level of psi as long as theres nitrous to shot so it will help when your bottle starts running low.
Old Jan 13, 2004 | 07:19 PM
How does it affect the vapors? So is it better or worse fot it?
And yea i do need a bottle warmer cause when i am down to 2 or 3 pounds left it is really useless to use cause it dosent hit as hard...
Old Jan 15, 2004 | 09:08 AM
InsaneCivicCoupe's Avatar
Retired Ricer...
if he gets a heater all it will do is raise the nitrous pressure....
more nitrous+less fuel= BOOOOOOOOOM!!!!!
you need more fuel bro and keep a close eye on that bottle pressure.... Or sell that and get a wet kit.....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Jan 15, 2004 | 11:58 AM
Sneakin Deacon's Avatar
PSSHHH x2
The reason people say it will run you lean is because it will..cooler air is more condensed air(more air molecules) and with everyone tuning(i use this loosely considerent changing jets is tuning) for warm weather since its florida...that 100shot can turn into a 125shot with a decent temp change. since it a dry kit, just swap the jet out for something smaller to be safe.
A wet kit would be no different...you'd still be changing jets.
as far as nitrous pressure..that plays a large roll in how much power you actually have (ever wonder why people buy heaters? they actually do something) 600psi on a 100shot jet would be alot less power than it would be at its 1000psi rating...also, going over makes more power aswell..some people have blown because of this fact aswell...there is a noticeable difference in a 900psi hit and a 1300psi hit.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
