Sponsored by: CARiD
SAFC boost and fuel question
Old Dec 9, 2003 | 02:36 PM
MOORESPEED12's Avatar
BRING IT!!!
Thumbs up SAFC boost and fuel question
I got a stock LS motor with turbo kit (62-1) SAFC and DSM 450 injectors. Im going to turn the boost up between 10-12 psi and I was wondering if some one could tell what they think I should run my fuel map at from 1000-8000 rpms. So far someone told me to just run it at -40% all the way across. Let me know what you think. Thanks
Tony
-Tony Moore (Moorespeed12@yahoo.com)
Old Dec 10, 2003 | 07:19 AM
99B16Si's Avatar
every car is different, u need to put it on a dyno w/ a wideband to have it tuned precisely
PS -40 across the board my work under partial throttle but youll need to compensate for the added boost pressure
Old Dec 10, 2003 | 07:56 AM
qitstrn's Avatar
Can you spot me 20 cars?
what do you have for an ECU? If it's stock you shouldnt have bigger then 370 injectors. 450's are big for a stock LS motor. I had 310"s for a while on a built gsr on 10 lbs.
Old Dec 10, 2003 | 10:48 AM
BRING IT!!!
thanks guys for the info I'll try it out...after the holidays I definitly plan on getting it on a dyno.
Old Dec 10, 2003 | 01:12 PM
qitstrn's Avatar
Originally posted by Vapor
you'll be lucky if you dont blow it at 10-12lbs on that turbo with only 450s running at 100% duty cycle. I'd set it at -31% all the way across, or the max you can run without throwing a cel for map sensor. I'd also get it on a dyno with wideband asap
when i had th 310's i was pushing 10 lbs with chipped ecu and vafc making 280/185 with 11.8 a/f all the way across. Why would he need that big of an injector? I dont know the car and all he has. I wanted to now how do you decide what size of an injector would be best for an aplication?
Old Dec 10, 2003 | 02:39 PM
2.3L SVO Turbo 4's Avatar
The Refugee Racer
get a whole new setup
Old Dec 11, 2003 | 01:28 AM
InsaneCivicCoupe's Avatar
Retired Ricer...
nah he just needs to get what he has tuned so he can come get some of the four door.....
good luck bro..... if you need help tunin the safc and gettin some dyno time shoot me a pm
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
