Sponsored by: CARiD
Noob to FI =\ questions
Old Oct 8, 2003 | 06:46 PM
FL_civic_rider's Avatar
Drive it like it's a Taco
Default Noob to FI =\ questions
HEy guys I'm a noob to the FI section, and know jack about it
I want to turbo my D16, but I was wondering if it would be possible to only push like 7 or 8 PSI on the stock motor till I got the cash to build it?
like can i toss a turbo kit on my stock motor and only run 7/8 psi and be safe?
I wanna do that for now and build my engine and push up the psi l8r.
also,
what parts are used in a turbo kit?
like piece by piece?
Turbo itself
intercooler
timer
controlor
BoV
I KNOW I'm missing parts so what else do i need?
thanx for the help guys!
Contact me:
Adam B.
Cell: (727) 742-0633
Old Oct 8, 2003 | 09:39 PM
psifactor's Avatar
Hello
Turbo is a great idea for some more power, but you may consider doing some more reading/learning first. I guess thats what you are doing here.
7-8psi will be within your limits.
Along with the things that you have mentioned you will need a better fuel system. Injectors, pump. FPR???
In your case you are probably better going with a kit from someone, but this will not be the cheap way to go.
A turbo timer is not necessary if you are working a budget.
Needed
Turbo
wastegate
exaust manifold
intercooler
all pipes
something to tune
boost guage
egt guage might be nice
bov
I know I'm forgetting some things.....
You should contact Cronic on this board. I forget if he has a D or a B series but he has a whole set up for sale, minus the IC.
Heavy car with a 2.5L
