Sponsored by: CARiD
turbo ecu management
Old Jul 26, 2003 | 05:29 AM
kender's Avatar
gadget man
Default turbo ecu management
I'm looking at hondata and the aem ems ecu systems and want to get opinions pro and con on both. I have an 88 crx si with b16 swap a t3 turbo .63a/r on the turbine and .43a/r on the compressor, it will be a daily driver on 9-10 lbs of boost. It will only see the track after Each upgrade just to see what it can do so things like launch control aren't neccessarily needed. I have heard the aem won't fit in the same area as the stock ecu, true or false? I plan on being able to run 22psi and daily drive 15psi, but thats down the road.
If I go hondata which stage would be best. I know for hondata to go see vapor, ( vapor if you read this please put in your 2cents, also do you guys tune the aem).
If I go aem who in the bay area tunes it.
I have found out that the hondata once originally tuned for a few boost levels it can then extrapolate any other boost levels you throw at it.
U.S.S.A Crew Member #001
Old Jul 26, 2003 | 08:16 AM
99B16Si's Avatar
what he said...
also that little turbo aint gonna do 22psi. at 8k rpm youll be lucky to get 8psi
Old Jul 26, 2003 | 06:52 PM
kender's Avatar
gadget man
the dude I bought it form ran 9psi at 3200 on a 2000si and the turbo map for the t3 on a .63 and a .48 both show the optimum rating ( the center island) between about 7psi and 16 psi, by the time I stand build a different b16 block I'll run a t3/t4. Holy shi* I just saw the price difference and I'll go with hondata, at least until the built engine comes along and I start rakin in cash with my bachelors.
Old Jul 27, 2003 | 07:52 PM
kender's Avatar
gadget man
I do have a laptop but I'm not into changing settings that crucial on the fly. I'll let secret services tune it then let it stay that way until I add more mods. by the time I get to 20+ psi I'll definately have a bigger turbo or I may find out that 15psi is enough for me. thanks for the info.
Old Jul 28, 2003 | 04:40 AM
Matt Vassallo's Avatar
lifelong learner
dude....
built motor, big cams, crazy intake manifold .. etc etc etc..
you can still do it with hondata. 650+ whp has been seen on hondata.
rest in peace tim.
Old Jul 28, 2003 | 05:51 AM
kender's Avatar
gadget man
sweeeeet, between the good stuff on hondata and the cost for what I want and secret services being able to tune it I think I'll be going with hondata.
