need help with PS CS
Old Apr 11, 2007 | 10:36 AM
Michael.'s Avatar
I'm a Photographer!
Default need help with PS CS
im a BIG TIME noob when it comes to editing pics. i just want to learn how to add a quick border in photoshop and maybe lighten/clear some bright pics up.
i learn and catch on quickly so explain things to me once, i may have one or two questions to make sure then im set!
thanx in advance
Nikon D300 | 10-20 | 18-50 2.8 | 70-300 VR | 50 1.8 | 80-200 2.8
Originally Posted by Petitt
Please take a look at our Photography section with your friend, and take some notes.
Old Apr 11, 2007 | 01:59 PM
DD.'s Avatar
DD.
Administrator
Maybe this will help...
For the boarder...Go to Select>All.
Then to Modify>Boarder
Then put in the amount of pixels you want for the boarder. Usually use 6-8.
Then color the boarder in with a brush with the color of your choice. Its best to start a new layer befor you color.
For the Brightness,Contrast,Saturation...etc. Go to Image>Adjustments.
Hope that helps some... Sorry there so small. You should be able to make it out though.
Old Apr 11, 2007 | 02:24 PM
EconoBox's Avatar
Four Door Mafia
Also you can go to Image>adjustments>canvas Size and add pixels all the way around without covering up any of the image.
Both ways work it is just personal choice and whether you can do the math in your head or not. : )
ECU Chipping, Tuning, Custom Wiring, and any other automotive needs. PM me for a quote.
Hmotors/Hondata/Hasport/JHPusa/PasswordJDM
stores. Most parts in stock or 1 day away!
Old Apr 11, 2007 | 02:30 PM
Michael.'s Avatar
I'm a Photographer!
awesome thanks! you should sticky this lol
Old Apr 12, 2007 | 03:21 PM
doeboy's Avatar
good info, how do you make a water mark?
1992 honda civic cx 2.0l
steeeeerrrrnss are gone
http://www.myspace.com/drew_doeboy
Nikon D50 w/ kit lens / Tamron 70-300mm DI LD macro AF/Nikkor 50mm 1.8f/Nikon SB-600 speed flash
Old Apr 12, 2007 | 04:27 PM
kaluwa's Avatar
You can also do a border this way..
- Ctrl + A (to select all)
- Select > Modify > Border > Chose Pixels > Select Pixels
- Edit > Fill
- Under the use drop down menu, choose color.
- Choose the color you want.
- Under the mode drop down menu, choose the mode you want.
Originally Posted by steezyteg
ok guy your the idiot.
Old Apr 12, 2007 | 04:30 PM
DD.'s Avatar
DD.
Administrator
I would just type what you want the mark to be, and then change the opacity.
Old Apr 12, 2007 | 05:12 PM
Projekt's Avatar
No
or you can just hit ctrl+a and then go to edit>stroke>3-4 pixels black, then hit ok or done.
border done.
