Paint, Body, and Detailing Discussions on how to keep your ride clean, shiny, and straight
Why we chose an alternator, not a generator, for our Elva
Old Nov 27, 2024 | 03:58 PM
Default Why we chose an alternator, not a generator, for our Elva
click code box for picture
Code:
Update by Tim Suddard to the Elva Mk VI project car
Nov 26, 2024 | Elva, alternator, generator, Elva Mk VI
As with much of this car’s history, details are also fuzzy regarding the charging system. Most of the 30 of the cars that Elva built were sprint racers and therefore wouldn’t have lights, except for presumably a brake light.
The two Mk VI endurance race cars–including our chassis No. 13 prepped for the 12 Hours of Sebring–definitely had lights front and rear as well as a light for the right-side number panel visible to crew and officials. Stripping down the body proved evidence of those lights, which helps us prove that the car had not been rebodied along the way.
So, we would need a charging system, not the magneto likely used on sprint racers.
Alternators had not become prevalent in 1962, so the car would have been equipped with a generator. Sadly, generators are heavy, inefficient and not as well suited for the high-rpm rigors of racing. (Trust us, we went through generators almost as often as we went through tires on our TR3 project a few years back.)
[Video: How to make the switch from a generator to an alternator]
So, thankfully, a company in England called Tudor has taken the appropriate Lucas 39/40 generator for a car like our Elva and reengineered the case to contain an alternator. We purchased one directly from their booth at the Beaulieu Autojumble and carried it home in our luggage next to all the other illegal substances.
For mounting bracketry, we called Coventry Climax engine expert Steve Sanett at Penta Motorsports. He told us that the FWA was configured for a generator bracket. He had them, or could make them, and he would be back in touch as soon as he had a solution. We will report on this bracketry and the installation as soon as we receive it.
The generator doesn’t come with a fan, though. We had an old Sprite generator in our parts box and cleaned, painted and installed the fan.
Old Dec 25, 2024 | 03:50 PM
Default The not-so-simple job of mounting an alternator to our Elva
Dec 24, 2024 | Elva, Restoration, Elva Mk VI
Our Elva Mk VI sports racer would have come originally fitted with a generator. We’d rather run an alternator but at the same time keep things looking period correct.
While visiting England’s Beaulieu Autojumble last fall, however, we found and an original Lucas generator that had been transformed into an alternator. This find offered us vintage looks and modern internals.
[Why we chose an alternator, not a generator, for our Elva]
Now we just had to figure out how to mount it to our Coventry Climax FWA engine. Steve Sanett of Penta Motorsports offered us the necessary bracket for about $300. While that seemed a bit pricey, hand fabrication does not come cheaply, and had the pieces fit, that would have been a fairly reasonable way to solve this conundrum.
He sent the pieces, and while beautifully made and powder coated, we had to remake the plate that bolts to the front of the engine as, at least on our FWA, the bolt holes did not line up. The adjusting bracket also had to be ground down a bit to clear a bolt on the timing chain cover.
In a couple of three-hour sessions–which admittedly included a few trips to the parts store to finally get the right belt–we finally had our alternator mounted: O’Reilly part No. 9395 measuring 40 1/8 x ½ inches. (For help on sizing a belt, we found some helpful tools at the Tameson site.)
A tip for figuring out belt length, too, when there’s no factory literature for that situation: Take an old belt, cut it so it’s no longer continuous, and wrap it around the pullies. Then mark the needed length with a silver marker.
And a tip for transferring bolt holes, as we had to do when remaking that mounting plate. Put a piece of a masking tape over the bolt holes on the old part. Lightly tap down over the holes and then carefully remove the masking tape. Now lay the tape on your new part. The holes should be perfectly lined up where you need them.
As with seemingly everything on this project, the simple 15-minute job of mounting the alternator to the engine ended up taking hours. Welcome to basically recreating something from nothing.
Previous
Investigating the origin of our Elva’s original rear brakes
All updates
Old May 28, 2025 | 07:07 PM
Default How to upgrade a classic car to a modern alternator
By Carl Heideman
May 28, 2025 | Restoration, alternator | Posted in Shop Work , Restoration & Renovation | From the March 2016 issue | Never miss an article
Alternator changes and upgrades are among the most common underbonnet modifications performed on British cars. We’ve seen hundreds of these swaps performed through the years. While some are appropriate and effective, we’ve witnessed–and fixed–too many that have ultimately caused some sort of expensive problem: an electrical meltdown, a spinning part thrown from the car, or maybe just something sticking itself into the radiator.
Bottom line: We think most alternator conversions are a waste of time. In fact, they’re often dangerous.
We know, them’s fightin’ words. Everyone wants a reliable alternator, and those Lucas contraptions don’t seem to hold up or generate enough current. To put it simply, they just aren’t the kind of outdated technology we want to see when we raise our hoods. However, anyone who took debate–or made fun of the debate kids–in high school knows that you can’t come out with fightin’ words without backing them up. So, allow us to state our case.
It’s clear that many modern alternators put out more current than their old Lucas counterparts. You could also argue that the newer units hold up longer. However, the alternator itself isn’t the problem in most alternator swaps; it’s the wiring and the mounting that get people every time, making smoke and nasty sounds almost inevitable.
Think about this: If you install a modern, 80-amp alternator and use the stock wiring that was designed for a 36-amp alternator, what’s the inevitable outcome? Many people reason that if the accessories will still require the same amount of current from the new alternator as they did from the original, then it’s safe to use the stock wiring.
This logic fails to take two words into account: current potential. If a component ever fails or a dead short accidentally occurs, something will attempt to draw the full current capacity of the new alternator. What does this mean for a big portion of the wiring harness? Melting, smoking and burning.
Here’s something else to consider: Slapping on that alternator with some hardware store bolts and getting the alignment “pretty close” will work for a while. Eventually, however, something’s going to break, let loose or fly off, and that alternator will be flopping around, waiting to short out or preparing to hit something.
Now that we’ve laid out our case and made our point, let’s set things right and talk about the correct way to upgrade to a modern alternator. A good conversion consists of three important elements:
  1. Picking the right alternator.
  2. Making a very solid mount and adjuster.
  3. Wiring the alternator correctly.
Pick the Right Alternator
From left to right: A Lucas Generator, a Lucas 16ACR 32-amp alternator, and a modern Denso 55-amp alternator
Some alternator conversions make more sense than others. For example, some of the early alternators with external regulators aren’t available anymore, so your only choice is to convert to something else.
Swapping a generator for an alternator is another advantageous move. Many generators can barely keep up with the charging demands of the headlights and starter, so they probably won’t cut it if you’ve added a stereo or a big ignition system. Most generators also use bushings instead of bearings; an alternator with a bearing-equipped rotating mass is a better option.
When it comes to generators and outdated alternators, we feel that it’s usually best to do what the factory eventually did: Upgrade to a good alternator.
If you have an MGA or early MGB, install the factory alternator from a later MGB. For a Triumph TR or a Jaguar E-type, do the same thing: Look toward a later model for a solution. You can source the stock mounting hardware and alternator instead of engineering them yourself, saving a good deal of time and effort. You’ll still have to modify the wiring, but having two out of three jobs done up front ain’t bad.
If you want more output than an OEM alternator, then it’s time to do some careful shopping. Many people use mid- to late-1970s GM alternators because they’re common, inexpensive and rather durable. Late-1970s Bosch alternators show up quite often, too–especially on MGBs, since the conversion is nearly a bolt-in proposition.
For our money, however, we would pick a compact Japanese alternator and do things right. While it’s a bit hard to find quality data and specifications on alternators, we try to match the unit to our particular application.
First, we find an alternator that will physically fit; usually, the more compact it is, the better. Then we consider the pulleys; while many modern alternators feature pulleys for multi-groove serpentine belts, we want one that has–or can at least accept–a pulley that uses a conventional V-belt. Ideally, our alternator will work with the stock belt; this way, we can grab a replacement at any auto parts store.
Next, we make sure we’re not going to spin the alternator too quickly or too slowly. We also try to find a multiple-wire alternator, as the one-wire pieces don’t have provisions for a dashboard warning indicator–also known as the idiot light.
Most Lucas alternators produce less than 40 amps of current, but modern alternators typically produce much more–often starting around 60 amps. As we’ve already hinted, most of our classics don’t need tons of juice, so we like to stick with a lower-output, compact alternator. We’ve found that the Denso alternators used on Japanese cars fit the bill very well. Our favorites are the ones that came on ’90s-era Geos and the ones that Gustafson Specialty sells.
How-To: Solidly mount your alternator
From left to right are poor, better and best options for mounting brackets
This is where conversions often fall apart. Many swappers choose the right alternator, but then they blow the deal by mounting it poorly. The alternator must be mounted so that it’s perfectly lined up with the other pulleys in the system. The mount must also be strong and capable of properly distributing stresses.
Go Double: We always mount our alternators on double ears or in double shear; too often we see single-ear mounts that eventually overstress a fastener or mounting ear. While many swaps rely on the ear of the water pump as a sole mounting point, we always use a second point for reinforcement, usually using 3/16- or 1/4-inch steel for our brackets.
Use the Right Fasteners: We also insist on close tolerances with all fasteners as well as hardware that properly matches with the holes. People often make the mistake of using metric bolts in American unit-sized holes and vice versa. This can quickly result in flopping, rattling, shaking, shifting and breaking.
Wire It Right
None
Once we’ve sourced the right alternator and correctly mounted it, we can tackle the wiring. Our modern alternator has more current potential than the original wiring can handle, so we need to rewire the system. Since we start this new wiring from scratch, we also like to incorporate some additional safety into the system.
Our method goes like this: We find the maximum current output capacity for our alternator, then pick an appropriate master charging wire size. We usually use the factory color for this wire, which is brown in Lucas systems.
Old May 28, 2025 | 07:09 PM
Default part 2 alternator not generator
Here’s where the extra safety comes in: We add a fusible link to this master charging wire. A fusible link, as the name implies, works as a fuse. If anything goes dramatically wrong, the fusible link will sacrifice itself and melt away, effectively saving the more expensive components. Once we have selected our main charging wire and fusible link, we use the original wiring setup as a guide to install them–usually from the alternator to the starter solenoid.
Assuming we can get our hands on a multiple-wire alternator, the next part of our wiring job is to make the dashboard’s idiot light work properly. This usually takes a little research, but most multiplewire units work by becoming “excited” with external voltage.
One side of the idiot light is linked to the alternator, while the other side is linked to positive 12 volts. (Technically, the voltage is closer to 13.5-13.8, but we’re sticking to the nomenclature of our nominal 12-volt systems.) When the key is in the On position and the alternator is not working properly, a ground condition occurs and illuminates the idiot light to indicate a problem. When the key is on and the alternator is operating properly, the alternator sends positive 12 volts back to the light, extinguishing it.
To deliver the necessary volts, we run an exciter wire between the alternator and the idiot light; on Lucas systems, this is usually a brown wire with a yellow tracer. If a car features a voltmeter or ammeter, however, no wiring modification is required to get the idiot light working; these gauges can usually pick up their signals downstream of the alternator wiring.
Our last step is to deal with the now-abandoned OEM wiring. When it comes to this task, there are two good choices and one bad one. The bad one is to let the wiring hang and potentially short out. A better choice is to disconnect the wires, then tape and hide them. We do this if we think there is a chance the car might return to the OEM configuration. After all, we wouldn’t want to complicate the process by cutting off the wiring components.
The other good choice is to completely remove the wiring from the loom so it doesn’t create any risk or confusion for anyone in the future. This usually requires cutting apart the loom’s outside wrapping and then rewrapping it, which is no trivial task. It does make things neater, however, so we often take this route.
All Good Things Take Time
We originally stated that most alternator conversions are bad news. However, we also showed you the proper approach to making your swap the exception. Doing things correctly will take additional fabrication, wiring and time, but the results will be worth it: You’ll end up with a safe, long-lasting and easy-to-service conversion.
Step 1
None
Alternators require a solid mount to prevent vibration-related damage. After making some quick measurements, we roughed out a mount from some 1/4-inch cold rolled steel.
Step 2
None
After some more measuring, cutting, welding, drilling and test fittings, our new beefy mount was starting to take shape. We just needed to give it a clean look with some grinding and painting.
Step 3
Put enough paint on it so it doesn't look like you just took it off a junk car.
None
Once we cleaned up the edges and applied a fresh coat of paint, the mount was ready for installation.
Hold mah beer and watch this! Don't buff off the crud. Suck a few more beers instead.
Better yet is to mount it before the paint dries so it will scratch it and prematurely rust.
Then you can say "Ah hate it when it does that....." and then do another crude install, you butthead!
Step 4
None
Instead of using an OEM sliderstyle adjuster, we fabricated a nicer component using a pair of rod ends and coupler sourced from McMaster-Carr.
Old May 28, 2025 | 07:10 PM
Default part 3 alt instead of gen
Step 5
None
Now it was time to address the wiring. Since our 60-amp alternator could potentially melt the OEM 12-gauge alternator wiring, we made up a new main charging wire using 10-gauge wire along with a 14-gauge fusible link. As a rule of thumb, a fusible link should be four gauge numbers smaller than the wiring it is protecting. We stuck to the factory color code–brown in this case. That way when the damn thing catches fire and burns, you won't be able to see where it burned.
Maybe the color brown is 'nother subtle statement about the quality of your install.
Step 6
None
We also made up a subharness for the exciter circuit and the charging light. These subharnesses vary from alternator to alternator, so it’s important to do your research
but we don't know where....In our case, we used a schematic provided by Gustafson Specialty who is no longer in business, but we washed the pigeon crap off of it enough that
most of the drawing was legible except for where the clorox got on it. We made up the 16-gauge wiring using the Lucas color code–brown with a yellow tracer.A subtle comment about the manure quality of Luuc-ass electrical parts.
Step 7
None
We connected the OEM charging wires to the externally mounted starter solenoid, which is the main wiring junction from the battery. We then removed the OEM wiring from this junction and wired in our new main charging wire and wrapped it with dollar-store quality scotch tape, so we could tell our decreasing number of friends that they "sure don't wire them like that any more!"
Step 8
None
The final installation looks stock. Since we took the time to tackle each step correctly, we now have a safe, long-lasting solution that uses the factory belt.
American Iron Tech
Dec 31, 2023 08:24 PM
Toyota/Lexus Tech
Mar 28, 2014 11:40 AM
Mar 28, 2014 09:53 AM
Mar 28, 2014 09:51 AM
