Paint, Body, and Detailing Discussions on how to keep your ride clean, shiny, and straight
Expert advise
Old Mar 6, 2008 | 08:13 PM
Rx7_guy's Avatar
Default Expert advise
Im going to painting my car...im not looking for show quality.
I understand that my compressor is not great for use with an HVLP..
I have a 2hp 33 gallon tank...but could I get away with painting a section at a time?
I get about 8 cfm @ 40 psi.
The gun uses 7cfm
thanks for your help..
JDM FC
Old Mar 7, 2008 | 03:26 AM
oldschool98's Avatar
Painter Extrodionaire
You might get a fender sprayed before you are out of air. Thats a small compressor.
Old Mar 10, 2008 | 02:52 PM
IThaJokaI's Avatar
Hates cars...
a 33 gallon tank with only 2hp is quite small.. Although its not a small tank. And you have to look at what CFM the gun uses at what pressure... You say you have 8cfm@40psi which means its even lower at 90psi which is what the gun should require. You could paint small areas at a time but Im not sure how the coverage will be with that CFM rating...
Old Mar 10, 2008 | 05:02 PM
jlmaxima4sale's Avatar
honestly you will be fine with that and shouldnt run out of air at all as long as your cfm on the gun is lower then the compressors .... a hvlp requires about 10-15 psi to run so 8 cfm at 40psi is plenty .... I spray my clear with a gun that takes up 9.6cfm and the compressor i use is 10cfm @ 40psi and i shoot the clear at 40-45psi and never have a problem even on a all over job....
