My Silvia is making a popping sound in the right strut...
Old May 1, 2003 | 12:04 PM
Silviagirl79's Avatar
Default My Silvia is making a popping sound in the right strut...
Hmm what could this be? We installed a front strut bar a few weeks ago. But we've been noticing a popping sound when we back out and turn from the right strut area.
Any ideas?
Old May 1, 2003 | 05:45 PM
Matt Vassallo's Avatar
lifelong learner
strut mount going bad ?
strut itself squeaking?
any loss of fluids ?
is the strut bar tighened down all of the way ?
rest in peace tim.
Old May 1, 2003 | 07:18 PM
box240mod's Avatar
tire eater
check to see if the spring is still seated correctly, there should be a nice groove for it to sit in. if its not propperly seated then it will click and shift around the bottom/top of strut areas... may have shifted when top bolts where off?
you may have to take wheel off to see if spring is correct.
Visit J1Nracing.com! Visit J1Nracing.com! Visit J1Nracing.com! Visit J1Nracing.com! Visit J1Nracing.com!
Box on FB
Old May 6, 2003 | 08:54 PM
neurovish's Avatar
bucket
bad upper mount is my guess
Old May 6, 2003 | 09:48 PM
Charles's Avatar
Senior Member
Could maybe be the bushing in the T/C rod of your 240sx too
92' Nissan 240sx
02' Honda VFR Interceptor
08' Tundra
Old May 13, 2003 | 11:37 PM
dsonik1's Avatar
Professional Drif-Tater..
It could also be the "control arm stabilizer". When they go bad it makes a popping noise that sounds like it's coming from the strut. Just a suggestion.
Doogie: "Hey did you notice I was tandem with you slidin around that corner?!"
Sonik: " Cool! Did it look hot?, cause if you ever get that close to f'ckin my car up again.... the fuzzy balls hangin from my mirror will be yours
Import Corner Inc.
6432 massachusetts ave
new port richey,fl 34653
1-888-520-9601
GO TO:www.importcornerinc.com
MYSPACE
www.myspace.com/bmwsonik
Old May 14, 2003 | 07:38 AM
lifelong learner
what the hell is the ' control arm stabilizer ? ' ??
rest in peace tim.
Old May 14, 2003 | 05:03 PM
Charles's Avatar
Senior Member
92' Nissan 240sx
08' Tundra
Old May 15, 2003 | 07:47 AM
Enthalpy's Avatar
TR Balla Donor Supreme
Question
Old May 15, 2003 | 08:49 AM
lifelong learner
as far as i know the s13 and s14 has a
Front lower control arm and bushing
front Tension Rod (also called strut rod) and bushing
strut and spring combination with upper strut mount
front swaybar
that does it for the suspension in the front..
am i missing something sonik ??
rest in peace tim.
