Problems clocking and installing turbo lines gtx3076r 1.06ar twin scroll
Old Nov 16, 2015 | 02:09 PM
zero2toy's Avatar
Yea, but can you turn?
Default Problems clocking and installing turbo lines gtx3076r 1.06ar twin scroll
Hello All,
Before I go to the local turbo shop I figured Id post my problem with clocking my turbo and turbo lines for my GTX3076r Twin scroll.
1. I purchased this turbo from Full-Race and it was already loose and I was able to get my center section and compressor housing all lined up or "Clocked". But when I tried to tighten down the bolts on the turbine side, I just couldn't get any wrench on 2 of them to tighten them down. I got 4 out of 6 but 2 are just so close turbine housing and space between turbine and compressor is so small i just cant get to them with any wrench/socket. I had to use a 1/2" 1/4drive socket on a tiny breaker bar just to get to the other 4. Im half tempted to grind down the 12point socket but figured there has to be a better way, and I cant be the first to run into this problem. Im thinking I could just get a smaller AR turbine housing but that's a ~$500 purchase I really shouldn't have to make.
Has anyone run into this? If so what did you do to tighten these down?
2. I used the circuit sports top mount kit for turbo lines. The Turbine housing is so fat that I cannot turn the -3 oil feed line onto the turbo feed fitting. The corners of the hose end nut hit the housing. Same goes with the one of the water line hose ends.
Any suggestions?
I hate to admit this but I have already took a dremmel to the turbine housing in 2 places and now have all my hose ends and fittings on the turbo. But now when the turbo center section is clocked so the oil drain will clear the t4 flange on my manifold pointing down, the hose end for the water feed is in the way of one of the bolts to tighten down the turbo for final positioning. This is really getting me mad. Ill also hate to admit it but this is my first turbo build, but seriously, every video or how to shows me how easy it is to clock your turbo, but those bolts are so accessible compared to my turbo. Im thinking this is an issue only with GTX3076r turbos with 1.06ar, but i do not have the experience to make this assumption.
Hope my explanation is clear enough. If you have questions, please ask. If you have a solution, please share.
So why don't you just throw more money at it?
Old Nov 18, 2015 | 11:57 AM
There are times that I customize wrenches to make them work better.
First time I did this years ago, was to make a thin wrench to tighten the
double nut on the top of a shock mount.
When you show a customized tool to the Snap-on tool guy, sometimes they
come out with it as a new product. LOL
For some reason, Sears comes out with innovative new wrenches months before
anyone else.....even without seeing what I made..... and theirs are also guaranteed for life.
Old Nov 18, 2015 | 12:01 PM
I also have no bad feelings about grinding on an overly thick housing
for a little additional clearance.
Frequently things are made for a target market, but universally don't fit
everything in the world.
That was what Hot Rodding was about years ago....making something instead of buying it.
These days if a 17 year old can't bolt it straight on, he doesn't know how to make it work.
Have any pictures of the things you overcame?
zero2toy
Oct 30, 2015 05:50 AM
b18civic
For Sale/WTB Honda & Acura
5
Jul 23, 2012 07:11 PM
CubanPowered
Toyota/Lexus Tech
Jun 18, 2007 05:21 PM
CubanPowered
Jun 18, 2007 04:13 PM
TampaWRX
Subaru Tech
4
Jul 1, 2003 04:43 PM
