car will not shut off
Old Jun 23, 2013 | 07:19 PM
sr20t4's Avatar
sr20t4
Default car will not shut off
i installed sr20det red top and harness, it starts up but will not turn off with the key, i have to pull the 80amp fuse before the engine will shut down. Any thing that i might have cross up, wrong plug connected. Any ideal.
91 240sx hatch is the car.
sr20t4
Old Jun 24, 2013 | 06:54 AM
KRUKED's Avatar
.....taste the rainbow
Didn't you have this problem before?
You know, somebody actually complimented me on my driving today. They left a little note on the windshield, it said 'Parking Fine.'
Old Jun 24, 2013 | 07:04 AM
sr20t4's Avatar
sr20t4
yes, but still no luck. some how its getting power feeding back to keep the car running. I disconnected ING switch, ING relay and will not shut down. the only way it would shut off is by pulling 80amp fuse.
sr20t4
Old Jun 24, 2013 | 08:06 AM
KRUKED's Avatar
I can't recall in your other thread if you tried a different ECU. If you haven't, try another one. I came across one once, same issue that you're having. The only way to shut the car down was by pulling the Alt. relay.
Old Jun 24, 2013 | 05:44 PM
DSMSpoolin's Avatar
Judge Fudge
wrong ECU. seen this quite a few times
Many cars: Sold
1990 black top SR 240sx Coupe: Current
They use shitty skylines like this as taxi's in japan
Old Jul 10, 2013 | 05:39 AM
sr20t4's Avatar
sr20t4
I used the same ecu not a different one. i did wire up the maf wrong at first and burnt a diode in the ecu, but after fixing the maf issue the car started but then will not shut off. do you think that the ecu is keeping the car running.
sr20t4
Ilovemyteggy
May 1, 2011 07:01 AM
jboyzTeg
Jan 24, 2010 09:42 PM
JohnnyPC1
The Ford Forum Lounge
Oct 25, 2007 11:38 AM
JoKiE crx4294
Oct 19, 2007 07:28 AM
