Questions on enthalpy tune and AFR's..
Old Apr 20, 2012 | 09:09 PM
OneCleanS14's Avatar
Default Questions on enthalpy tune and AFR's..
Ok before I start I'll give a list of what's done to my motor before I start explaining.
KA24DES15 T28 on 9 PSI.
370cc injectors.
N60 MAF (pull through)
BKR7E gapped to .26 or .28 iirc.
Walbro 255
Z32 fuel filter
4.36 diff with s15 hlsd.
Stock ignition wires
Stock FPR
Stock block
Stock head
So I'm curious about my enthalpy tune. Main concern is with my AFR's. Cruising at pretty much any speed from 15-50mph the afrs bounce between 10.3-14.5 it'll be in the 14s for like 3 seconds, drop down to the 10s and just keep bouncing to 13s and back to 10s for awhile then go back to the 14s for a few seconds, then back down to the 10s and so on. Meanwhile my foot is completely still holding the gas pedal in the same place. This just doesn't seem normal to me.
Then on the highway, from 50-85mph again just cruising hold my foot as still as possible, the AFR's will be bouncing from 10.2-12.3~ then again for a few seconds it jump to higher 13s and 14s then jump down again.
Then always at WOT at full boost the afrs are exactly at 10.0 any speed any gear.
Sooo is all of this normal with the bouncing AFR's or no? To me it should be steadier than what I'm reading.
Also some things I've replaced from what I have researched that may be the culprits but have not helped:
Coolant temp sensor
Plugs. Switched from bkr7eix to bkr7e
Fuel filter
All of the injector o rings.
KA-T.
Enthalpy Tuned.
Old Apr 20, 2012 | 09:35 PM
omgosh's Avatar
Boost leaks maybe. How old is the o2 sensor?
Old Apr 20, 2012 | 10:20 PM
No boost leaks. Did a boost leak test. and the 02 sensor. The one on the elbow.. Is factory aaand the motor has 185k
KA-T.
Enthalpy Tuned.
Old Apr 20, 2012 | 10:57 PM
KRUKED's Avatar
.....taste the rainbow
Who tuned it, how long ago and when did the problems start to occur?
Edit: is there any hesitation or significant problems?
You know, somebody actually complimented me on my driving today. They left a little note on the windshield, it said 'Parking Fine.'
Old Apr 21, 2012 | 05:09 AM
Jr_SS's Avatar
S one 4
Why don't you have Martin throw it on the dyno and clean it up for you? Hell you're close enough that I'd be down there to get it straightened out.
Old Apr 21, 2012 | 07:56 AM
mewantkouki's Avatar
no
Re-calibrate your TPS voltage. My car used to do weird things in extreme temperature changes.
Old Apr 21, 2012 | 08:54 AM
Blackzenki82's Avatar
(OO\____/OO)
Or at least check it, so 10 points to griffendor Kevin!
RS-E tunes are 99% right, and if you're reading like you are with your AFR's, is most likely a mechanical failure somewhere.
+1 on having him run it on the dyno, at least a few pulls to see where it's at, and mybe help diagnose the problem in a controlled environment.
Originally Posted by sean1
Shit'll buff out.
Old Apr 23, 2012 | 07:25 AM
Empire's Avatar
buildin' it
i'm sure factory o2 sensor with 185K on it isn't helping either.
Old Apr 23, 2012 | 09:15 AM
omgosh's Avatar
If it works it works. I was referring to the wideband. They go out a lot faster.
Old Apr 23, 2012 | 06:21 PM
Super Coupe's Avatar
Old school TR member
I would check my wideband sensors are notorious for going bad. LC1's need to recalibrated more so than other brands.. Check your TPS voltage. Bad o2 or one that is going out could also cause this esp. seeing as it has such high mileage.
kaleonearth
Proven Power
Nov 30, 2011 06:29 AM
92RMS13
For Sale/WTB Nissan
8
Sep 30, 2011 09:54 PM
XMasta19
For Sale/WTB Nissan
Aug 13, 2009 02:18 PM
hillbillydrifter
Nissan/Infiniti Tech
5
Jul 14, 2008 08:25 PM
aznkrunk
Subaru Tech
16
May 27, 2006 09:21 AM
