Welding your diff.
Old Jul 1, 2011 | 07:32 PM
Blackzenki82's Avatar
(OO\____/OO)
Default Welding your diff.
Well i got my diff professionally welded by my buddy Josh Napoli of J&K Machine shop today to my specs, and since it was the PROPER way or at least PROCESS of prep cleaning and welding, i figured since i was having it done right, I'd take pics and maybe show the new guys how to clean/weld their diffs my way, as well as many others.
I'll keep this short and to the point with pics and captions, sorry for the lower quality but i didn't think I'd do a write up.
Step 1. Clean your Diff
. let it drain completely, if you're in your garage, use brake parts cleaner (the kind that doubles as a flame throwing spider killer), and thoroughly clean the spider gears, and as much of the inner housing as possible. as shown, it's in a parts washer.
Clean on the inside clean on the outside, clean on the inside clean on the....
finish it up with brake parts cleaner (make sure to hit both sides thoroughly)
in my case, i chose to run with gusset plates for added insurance.
bing bing, one on right was trimmed after this photo.
Step 3. SECURE THE DIFF!!
also secure the ring set as shown, tack weld the top of each spider gear on both sides, make sure tack, turn, tack turn, or you'll overheat the bearings.
Step 3. WELD!
usually you can just fill in the ring set, but as shown, i chose to run gussets, you can see the fill around it, do so similar without the gussets, weld, turn, weld, turn
Allow cool down as necessary, i chose to let it cool with the all the filler, so while it did, i got to ride this sketchy bitch for about 45 minutes....
Why Bar Stool?.................... Because Racecar.
then, throw in 2.5 quarts of the cheapest 75w90 you can find, install it and rape face (on the track).
Once again, thanks go out to Josh Napoli of J&K Machine shop, they do full machine work and are top quality, also to my girlfriend for putting up with me and my "drift car".
Fin.
Originally Posted by sean1
Shit'll buff out.
Old Jul 1, 2011 | 07:42 PM
omgosh's Avatar
Let me know how that works out once its in the car. Im curious cause I took mine completely apart for fear that something might warp. But there are those pressed on bearings that I cant take off anyway, so it kinda defeats the purpose of disassembling first.
I already have a welded in teh car but its fucked up...and Im still on the fence about welding this other one.
Old Jul 1, 2011 | 07:47 PM
(OO\____/OO)
i personally welded my last one, i used the "garage" route as above with a smaller gas welder, didn't run gussets, but if you fill, turn, fill turn, it allows the heat to evenly spread, even allow for smoke breaks for some cool down in between turns. the turning is not only for cooling, but to keep the diff spinning between welds, it will seize up if you run it too hot, like always, just make sure you have good penetration.....
I'll be using it at CFRC on the 8th, driving down on it, and back, I'll let you know how it goes.
Shit'll buff out.
Old Jul 2, 2011 | 01:11 AM
supreams14's Avatar
Brake Cleaner = Phosgene Article
Cleaning parts with brake parts cleaner then welding those parts makes a gas called arsenic!!!
It could only kill you is all!!!
Buy welders part cleaner next time!!!
Old Jul 2, 2011 | 07:31 AM
Davetheslave's Avatar
Good write up. The bar stool go cart looks awesome.
Formerly Earlkel OG join date 8-14-2003
Old Jul 2, 2011 | 08:35 AM
(OO\____/OO)
he was using that parts cleaner, i've used BPC in the past, and i'm still alive and kicking... might explain that extra inch i got downstairs though... nahmeen?
Shit'll buff out.
Old Jul 2, 2011 | 10:53 AM
omgosh's Avatar
IF you use brake parts cleaner, just make sure you let it evaporate for a while. You can hit it with a torch too to burn everything off first..
Old Jul 2, 2011 | 09:09 PM
supreams14's Avatar
Just a heads up. Dieing over some dumb shit is gay
Little Nicky
Drifting
29
Jul 7, 2006 04:16 AM
kevin d15
Drifting
24
May 3, 2006 05:56 AM
Khefran da Neferious
Drifting
15
May 1, 2006 02:25 PM
zenki_s14
Drifting
13
Jan 22, 2005 04:36 PM
