problemssss
Old Jan 18, 2011 | 03:54 PM
skimfor727's Avatar
Andy_MIDDz
Default problemssss
hey tr. im a noob in the 240 game, i have an s13 coupe and im having problems with the speedometer(not working). not really sure what to do to fix it. it has a swapped duel cam ka in it. so the gauges are from a different car. so im not sure if that has anything to do with it but id figure to give a lil more info.
please no negative comments. im trying to learn not get embarrassed..
thanks
Old Jan 18, 2011 | 06:20 PM
KendallH's Avatar
JDM cavaliers
Get under it and see if theres a harness on the trans. I know it sounds simple but my dual cam swapped car was missing the entire harness and the speedo/odo didn't work.
Originally Posted by PJ Prendergast
i went to a scrapyard in Kilcock today looking for my 180sx tail lights, no luck though
...and then I wondered why I was on Stanceworks forums...
Old Jan 19, 2011 | 05:49 AM
Empire's Avatar
buildin' it
start with that ^
then trace the wire from the speed sensor to the plug to make sure it is actually connected.
from there, I would say check the connection on the back of the cluster, it might be crappy or loose, or whatever from when the cluster was swapped.
Then, might have the change the cluster itself... they do go bad...
Have you been able to get fast enough to see if you're hitting the speed cut yet? That would narrow it down to being the cluster if the ECU is getting the signal.
Old Jan 19, 2011 | 08:40 AM
mewantkouki's Avatar
no
Duel cam ka
Old Jan 19, 2011 | 09:24 AM
Empire's Avatar
buildin' it
^ lol.
I was going to let it slide because he was new...
Old Jan 19, 2011 | 11:34 AM
DSMSpoolin's Avatar
Judge Fudge
yea my old cluster pooped out on me. check to make sure your cluster isnt bad if thats not it check your TCU. the TCU is a little white box pretty much on the floor of the drivers side. right next to your left foot if your sitting in it.
Many cars: Sold
1990 black top SR 240sx Coupe: Current
They use shitty skylines like this as taxi's in japan
Old Jan 21, 2011 | 06:27 AM
EfWorld's Avatar
iv got the same problem, but my rpm's dont work and my speedo works when it wants, most the time stuck on 130mph lol. im sure its my cluster though
TR "Old Skool EF" Member #48
99 Mitsu Eclipse GS-T DD
91 Honda CRX Si
91 Honda Civic Si
91 Honda CIVIC Si FOR SALE da front brakes. mint interior, 650 buks
