Spedometer, gas, odometer, temp guage not working
Old Jan 14, 2011 | 06:16 PM
Superman Race's Avatar
93 rx-7 my baby
Default Spedometer, gas, odometer, temp guage not working
98 5 sp nissan 200sx, the guages are not functioning. gas guage gives me orange light when the gas is low but the stick is half way gas. other guages don't work at all. rshared_pm works. thanks i appreciate it. i heard the speed sensor would fix the speed and odometer but im not sure if that would cause the fuel and temp guage too.
Old Jan 14, 2011 | 08:05 PM
Empire's Avatar
buildin' it
sounds like your cluster is just taking a crap on you.
It is possible that the sensors themselves are going bad, but I doubt it.
Clusters go bad.
I had a car that the fuel gauge would act up occasionally, then the speedometer would randomly cut off, and with the speedo not working, the odometer won't work, then the coolant temp gauge would only go between the bottom line and the next one up, no higher or lower. Eventually, it all just stopped working. The tach was the last to go.
Swapped out the cluster, and everything was fine.
