Brakes locking up
Old Sep 27, 2010 | 07:38 PM
KendallH's Avatar
JDM cavaliers
Default Brakes locking up
Just bought my first s13, and I guess it had been sitting for a while before I bought it. On the way home I'd say I had driven about 2 miles or so when the front pass brakes locked up and the car would barely move. Pulled over and let them cool down and the car was rolling again (albeit I was using engine braking and ebraking to limp home). The rotors look fine so I'm thinking its not the rotors/calipers/pads. I'm thinking its the rubber lines and old fluid and all it needs is a flush/bleed and new rubber lines?
Old Sep 27, 2010 | 08:03 PM
mewantkouki's Avatar
no
Sounds like you might have a seized caliper.
Old Oct 2, 2010 | 03:08 PM
Jared Noriega's Avatar
I have calipers ill give u for like 25 bucks if thats the case
Old Oct 3, 2010 | 01:03 AM
RobRobking18's Avatar
call me puppy
same thing happened to me. Never found the issue. I replaced the calipers, master, booster, bled them, still would lock up. Finally switched shells lol
Old Oct 3, 2010 | 08:29 AM
asia989's Avatar
Why So Serious?
replace the check valve, if not replace the booster. Wifes car did the same thing
No Front Bumper Mafia crew#1 since 04'
The original 350Z Blue 240sx
Old Oct 4, 2010 | 12:59 PM
Empire's Avatar
buildin' it
the master could be bad/goin' bad. it adds pressure, but won't let the pressure go. Happens a lot after sitting for a while.
Old Oct 4, 2010 | 08:10 PM
KendallH's Avatar
JDM cavaliers
Bought a new caliper and tossed it on today. Brakes seem to be good to go. Took it for a 10 minute test drive and no seizing or fade.
Old Oct 11, 2010 | 06:52 PM
KendallH's Avatar
JDM cavaliers
Bought a new front pass caliper (the one that originally locked up) and then the rear pass locked up. Tossed on a new one from advanced, went for another ride and now the front driver is locked. I'm thinking this isn't the calipers then? Check valve or booster someone said?
Old Oct 12, 2010 | 07:55 AM
Empire's Avatar
buildin' it
check valve just controls the vacuum going to the booster. The booster just makes your pedal "pushable" it assists by, in a simplistic nutshell, amplifying the force you are putting on the pedal to move the piston inside the master cylinder. Without a booster, the pedal would be very hard to push.
I would bet that the master cylinder itself is bad, or going bad and putting the new calipers on is just masking the problem.
The other theory is that the fluid itself is bad. Brake fluid absorbs water so over time, it goes bad. Too much water in the lines would lower the temps needed to boil the fluid. boiling fluid will put pressure on the caliper causing it to seize up. But the caliper would release after letting it cool off for a little bit.
Try this. Drive it til the caliper seizes up. Then let it sit. But leave the engine running so there is still vacuum on the booster. If the caliper lets go in 10 to 15 ish minutes, then you know it was fluid related and all you need to do is flush the whole system out. If it doesn't let go, then you know it is either the caliper itself, or the master cylinder. If all of the calipers were locking up, then I would say it was the booster. It could technically be a combination of the booster and the master. The master is going bad and the booster isn't letting go of all of the pressure keeping a little bit on the piston in the master which, because it is bad, is causing that extra pressure to be focused on one caliper. A bit of a stretch but could happen. Anyway, back to what I was saying, if the caliper lets go, great. If not, then rule out the possibility of it being the master. Take someone's good master/booster from their car and bolt it up to yours real quick. work all of the air out of the lines and go for a ride. If it locks up again, then you know it is the caliper itself (or you didn't get all of the air out, so try to bleed it again just to be sure) You could just have crap luck and all of the calipers are going bad at all about the same time.
Then put your buddies car back together, and get a ride to the parts store to buy what you need and fix your car.
Old Oct 12, 2010 | 09:34 AM
KendallH's Avatar
JDM cavaliers
Thanks for the help, I think I'm gonna try blocking off the booster and driving with manual brakes (I have manual brakes in my gran torino so I know what thats like). If they still lock up, that should eliminate the booster right? Then all thats left should be the master and fluid.
